Virgo Tools for Eclipse Luna and Mars [message #1699590] |
Thu, 25 June 2015 09:36 |
Hi all,
I tried to install the Virgo Tools both in Eclipse Luna and in Mars (JEE packages), from this update site:
"Virgo IDE Releases" - http://download.eclipse.org/virgo/release/tooling
- Eclipse Virgo Tools 1.0.1.201302270038-RELEASE
but I got errors (see below).
Instead all il working well with Kepler.
Some suggestions?
Thank you very much.
Vincenzo
Cannot complete the install because of a conflicting dependency.
Software being installed: Eclipse Virgo Tools 1.0.1.201302270038-RELEASE (org.eclipse.virgo.ide.feature.feature.group 1.0.1.201302270038-RELEASE)
Software currently installed: Eclipse IDE for Java EE Developers 4.5.0.20150621-1200 (epp.package.jee 4.5.0.20150621-1200)
Only one of the following can be installed at once:
OSGi System Bundle 3.8.1.v20120830-144521 (org.eclipse.osgi 3.8.1.v20120830-144521)
OSGi System Bundle 3.10.100.v20150529-1857 (org.eclipse.osgi 3.10.100.v20150529-1857)
Cannot satisfy dependency:
From: Eclipse IDE for Java EE Developers 4.5.0.20150621-1200 (epp.package.jee 4.5.0.20150621-1200)
To: org.eclipse.epp.package.jee.feature.feature.group
From: EPP Java EE IDE Feature 4.5.0.20150621-1200 (org.eclipse.epp.package.jee.feature.feature.group 4.5.0.20150621-1200)
To: org.eclipse.m2e.feature.feature.group 0.0.0
From: Maven Integration for Eclipse 1.6.0.20150526-2032 (org.eclipse.m2e.core 1.6.0.20150526-2032)
To: bundle org.eclipse.osgi 3.10.0
From: m2e - Maven Integration for Eclipse (includes Incubating components) 1.6.0.20150526-2032 (org.eclipse.m2e.feature.feature.group 1.6.0.20150526-2032)
To: org.eclipse.m2e.core
From: Eclipse Virgo Tools 1.0.1.201302270038-RELEASE (org.eclipse.virgo.ide.feature.feature.group 1.0.1.201302270038-RELEASE)
To: org.eclipse.virgo.ide.manifest.core [1.0.1.201302270038-RELEASE]
From: Eclipse Virgo IDE (Manifest Core) 1.0.1.201302270038-RELEASE (org.eclipse.virgo.ide.manifest.core 1.0.1.201302270038-RELEASE)
To: bundle org.eclipse.virgo.kernel.artifact 0.0.0
From: Virgo Kernel Artifact Integration 3.6.0.RELEASE (org.eclipse.virgo.kernel.artifact 3.6.0.RELEASE)
To: package org.eclipse.virgo.nano.serviceability [3.6.0,3.7.0)
From: Virgo Nano Core 3.6.0.RELEASE (org.eclipse.virgo.nano.core 3.6.0.RELEASE)
To: package org.eclipse.osgi.internal.baseadaptor 0.0.0
[Updated on: Thu, 25 June 2015 09:36] Report message to a moderator
Re: Virgo Tools for Eclipse Luna and Mars [message #1699621 is a reply to message #1699600] |
Thu, 25 June 2015 11:29 |
Hi GianMaria, Florian,
thank you!
Just for a note I tried that update site on Mars (with Java8) and had this error:
Cannot complete the install because one or more required items could not be found.
Software being installed: Eclipse Virgo Tools 1.0.1.201506250039-SNAPSHOT (org.eclipse.virgo.ide.feature.feature.group 1.0.1.201506250039-SNAPSHOT)
Missing requirement: Artifact Repository 3.7.0.D-20150624084347 (org.eclipse.virgo.repository 3.7.0.D-20150624084347) requires 'package org.eclipse.virgo.util.osgi.manifest [3.7.0,4.0.0)' but it could not be found
From: Eclipse Virgo Tools 1.0.1.201506250039-SNAPSHOT (org.eclipse.virgo.ide.feature.feature.group 1.0.1.201506250039-SNAPSHOT)
To: org.eclipse.virgo.repository [3.7.0.D-20150624084347]
I will try it next with Luna (4.4)
Thank you
Vincenzo
[Updated on: Thu, 25 June 2015 11:30] Report message to a moderator
Re: Virgo Tools for Eclipse Luna and Mars [message #1699721 is a reply to message #1699621] |
Fri, 26 June 2015 07:39 |
Sorry, I have to correct myself: today I retried with a brand new Mars/JEE+Java8 and a brand new workspace:
the error is related to missing org.json bundle.
Software being installed: Eclipse Virgo Tools 1.0.1.201506260038-SNAPSHOT (org.eclipse.virgo.ide.feature.feature.group 1.0.1.201506260038-SNAPSHOT)
Missing requirement: Eclipse Virgo IDE (Server Core) 1.0.1.201506260038-SNAPSHOT (org.eclipse.virgo.ide.runtime.core 1.0.1.201506260038-SNAPSHOT) requires 'bundle org.json 0.0.0' but it could not be found
From: Eclipse Virgo Tools 1.0.1.201506260038-SNAPSHOT (org.eclipse.virgo.ide.feature.feature.group 1.0.1.201506260038-SNAPSHOT)
To: org.eclipse.virgo.ide.runtime.core [1.0.1.201506260038-SNAPSHOT]
seems like Mars/JEE doesn't contain org.json ... which is quite strange ...
With Mars/JEE+Java7 instead the detailed error is:
Missing requirement: OSGi Framework Editor UI (Incubation) 0.2.0.201206060754 (org.eclipse.libra.framework.editor.ui 0.2.0.201206060754) requires 'bundle org.eclipse.zest.core [1.0.0,2.0.0)' but it could not be found
Missing requirement: OSGi Framework Editor UI (Incubation) 0.3.0.201212132137 (org.eclipse.libra.framework.editor.ui 0.3.0.201212132137) requires 'bundle org.eclipse.zest.core [1.0.0,2.0.0)' but it could not be found
Missing requirement: OSGi Framework Editor UI (Incubation) 0.3.0.201305070844 (org.eclipse.libra.framework.editor.ui 0.3.0.201305070844) requires 'bundle org.eclipse.zest.core [1.0.0,2.0.0)' but it could not be found
Missing requirement: OSGi Framework Editor UI (Incubation) 0.3.0.201305151323 (org.eclipse.libra.framework.editor.ui 0.3.0.201305151323) requires 'bundle org.eclipse.zest.core [1.0.0,2.0.0)' but it could not be found
Missing requirement: OSGi Framework Editor UI (Incubation) 0.3.0.201305311343 (org.eclipse.libra.framework.editor.ui 0.3.0.201305311343) requires 'bundle org.eclipse.zest.core [1.0.0,2.0.0)' but it could not be found
Missing requirement: OSGi Framework Editor UI (Incubation) 0.3.1.201405141436 (org.eclipse.libra.framework.editor.ui 0.3.1.201405141436) requires 'bundle org.eclipse.zest.core [1.0.0,2.0.0)' but it could not be found
To: org.eclipse.virgo.ide.runtime.ui [1.0.1.201506260038-SNAPSHOT]
From: Eclipse Virgo IDE (Server UI) 1.0.1.201506260038-SNAPSHOT (org.eclipse.virgo.ide.runtime.ui 1.0.1.201506260038-SNAPSHOT)
To: bundle org.eclipse.libra.framework.editor.ui 0.0.0
With Luna/JEE SR2 instead all is working well, both with Java7 and Java8
Vincenzo
Re: Virgo Tools for Eclipse Luna and Mars [message #1699833 is a reply to message #1699787] |
Fri, 26 June 2015 23:47 |
Hi Florian,
thank you for your answer.
I have always the option "Contact all update sites ..." checked, but ...
... it turned out that I hit this issue
https://bugs.eclipse.org/bugs/show_bug.cgi?id=470900
(==oomph cache blocks access to some update sites)
so the needed features where not allowed to be correctly retrieved.
(indeed I noticed that in last few days when I hit by chance Mars main update site I received an error, but didn't take much care about this...)
In the end just by deleting oomph cache
C:\Users\<user>\.eclipse\org.eclipse.oomph.p2\cache
solved the problem and now I can install Virgo Tools snapshot on Mars, both with Java7 and with Java8.
Thank you very much!
Vincenzo
Re: Virgo Tools for Eclipse Luna and Mars [message #1699945 is a reply to message #1699917] |
Mon, 29 June 2015 12:42 |
Hi Florian,
me too was thinking to be using a clean installation (I always unzipped the eclipse package in a brand new folder and used a brand new workspace),
but keep in mind that since Mars onwards everyone is always using Oomph (often wihtout being aware of that!) and so the folder <user>\.eclipse\org.eclipse.oomph.p2\cache enters in the play inevitably ...
Vincenzo
FUDForum. Page generated in 0.05026 seconds
