Re: WB causes Eclipse to hang after closing Preview window [message #1698766 is a reply to message #1698739] |
Wed, 17 June 2015 16:20 |
Anirudh Bagde Messages: 3 Registered: June 2015 |
Junior Member |
One thing to note is that the AWT-EventQueue-0 thread seems to be missing from the thread dumps. I think the problem is that somehow, the event dispatch thread is exiting before the lock is being notified, but after the actual window is disposed, since the window does close despite Eclipse being hung. So, some sort of race condition is going on.
This all happened when I was running on OpenJDK. The issue seems to be gone with Oracle Java. There's probably a bug that needs to be reported somewhere, but I'm not sure where. Is this a bug in the way WB deals with showing preview windows, or a bug with OpenJDK? For the record, the image of the window in the Design tab works fine, and clicking the refresh button works fine too, without causing any issues. The problem only happens when opening the preview window, and then trying to close it.
FUDForum. Page generated in 0.03771 seconds
