Re: Creating ReqIF model programmatically [message #1696363 is a reply to message #1696222] |
Tue, 26 May 2015 06:13 |
Hello Furkan,
Glad to hear you oculd figure out how to build a model.
> I cannot set the name of the specification document and spec objects. I have setted the desc. of SpecificationType and SpecObjectType. nothing happened.
The name in the GUI is actually taken from the AttributeValues. There is a separate configuration that decides which values are used. In the GUI, you configure it via ProR | General Configuration | Default label.
I assume that you want to do this programmatically: This information is stored in the tool extensions, and there is a separate plugin (I think called org.eclipse.rmf.pror.configuration or similar), which contains the eCore model and code for accessing it.
Best,
- Michael
FUDForum. Page generated in 0.04028 seconds
