Re: Linking in between modules [message #1668066 is a reply to message #1666227] |
Thu, 12 March 2015 10:10 |
Hi Frieder,
> It is planned to use GIT on several files.
We have a simple EMF Compare integration (as part of Pror Essentials). It's not great, but we have improving it on our todo-List. With this, git-integration should not be a problem.
> Our project environment has a need for links between requirements which are located in different modules
Not sure what you mean. You could mean one of two things:
1. Linking within two Specifications within the same .reqif file: Adding the showing and navigation in the other direction is not difficult, it just needs to be done (i.e. we need someone to do it or to pay for it).
2. Linking across Files: This is possible according to the ReqIF Spec, but there are a lot of details to consider. We have an implementation spec, but likewise look for help or money to do it.
> Furthermore, it would be nice to have a single configuration (Datatypes/Spectypes) which is applicable for several modules at once.
I agree. Something like this does currently not exist, unfortunately.
Are you in the position to help us out on these features, either with manpower or funding? If so, please contact me directly (via formalmind.com).
Best,
- Michael
Re: Linking in between modules [message #1674569 is a reply to message #1671226] |
Sat, 14 March 2015 20:25 |
Hello Frieder,
> Regarding the modules: I meant the 2nd of your propositions.
We have a spec for this scenario, which provides a mechanism for creating a set or related .reqif files. If you have someone willing to implement it, I can provide you with it.
> We need to link across files for which I see some issues such as the Identifier attribute. Is it ensured that each idientifier is unique and only assigned once, even though different files are used?
If Identifiers are generated by ProR, they are globally unique. But if a file is copied, the uniqueness is gone, of course. Also, .reqif file may come from other sources. So no real guarantee.
> Regarding the single config: do you have some kind of workaround for that?
Sorry, no.
> For my use case, I unfortunately cannot offer any developmen capacity or money to implement new features into ProR. However, I'll have to verify...
Let me know if there is an option.
Best,
- Michael
FUDForum. Page generated in 0.03354 seconds
