Topic |
Replies |
Views |
Last message |
Custom data source How do I use the contents of a text file as a data source? |
2 |
1744 |
Tue, 20 October 2020 07:03 By: Phil Pinder |
Creating Data Set sort Available Fields box Need help for possibly sorting Available fields. |
4 |
1373 |
Tue, 20 October 2020 06:39 By: Nikolai Elders |
Subheadings for Report How to add month sub-headings to a report |
1 |
1688 |
Mon, 19 October 2020 21:55 By: rbaak Mising name |
custom page parameter for validation Need help with creating a custom page paramater for parameter validation |
1 |
814 |
Mon, 19 October 2020 21:45 By: rbaak Mising name |
Birt group header based on page |
3 |
7903 |
Mon, 19 October 2020 21:16 By: rbaak Mising name |
BIRT Report - Table skipping positions until other tables have finished |
1 |
2405 |
Mon, 19 October 2020 20:55 By: rbaak Mising name |
Dynamic Display of grid |
2 |
9776 |
Mon, 19 October 2020 20:49 By: rbaak Mising name |
Page Break Issue |
4 |
3457 |
Mon, 19 October 2020 20:43 By: rbaak Mising name |
0 |
1639 |
Mon, 19 October 2020 11:14 By: Nikolai Elders |
BIRT 4.8.0 source code BIRT 4.8.0 source code |
0 |
1720 |
Fri, 16 October 2020 07:06 By: Makarand Kurkute |
Report PDF/WORD on Linux OS extra line breaks By: Raj J on Wed, 14 October 2020 |
0 |
1133 |
Wed, 14 October 2020 09:11 By: Raj J |
getting a specific table value then passing it to a variable |
2 |
2123 |
Tue, 13 October 2020 13:50 By: rbaak Mising name |
Setting base_url at runtime. Any way to set the base_url runtime? |
0 |
1798 |
Tue, 13 October 2020 11:04 By: Makarand Kurkute |
Install BIRT By: A S on Fri, 11 September 2020 |
1 |
2163 |
Mon, 12 October 2020 07:27 By: dmitry khotsko |
Page footer only on last page (PDF format target) |
4 |
6480 |
Mon, 12 October 2020 07:21 By: dmitry khotsko |
Excel print - Fit content in one page Adjusting scale percentage in excel |
0 |
1506 |
Fri, 02 October 2020 19:06 By: Jack Yang |
BIRT Report: Fix Marker Line on y-axis which is used as target line Fix Marker Line on y-axis which is used as target line |
0 |
1300 |
Mon, 28 September 2020 19:30 By: ganop 123 |
BIRT Exception - Data Set script method "Fetch" returned null; expected a Boolean value BIRT Exception |
0 |
2667 |
Fri, 18 September 2020 12:13 By: Hardik Patel |
Passing parameter in Xpath expression in Row mapping of Data set |
0 |
2215 |
Fri, 18 September 2020 05:08 By: Himani Himani |
BIRT web service REST (JSON) |
4 |
9076 |
Wed, 16 September 2020 10:50 By: Malti Gumber |
gRPC support |
0 |
2079 |
Tue, 15 September 2020 07:38 By: Armin Galliker |
Birt All in one design a report file can't open again Birt All in one design a report file can't open again |
2 |
3103 |
Thu, 03 September 2020 18:45 By: Matt Bryant |
use wp_get_current_user() as parameter in BIRT Retrieve Wordpress Current user and use as parameter in BIRT |
0 |
9328 |
Sat, 29 August 2020 11:06 By: Michel de Vries |
Eclipse Birt - Remove default sorting of dimensions in data cube Eclipse Birt - Remove default sorting of dimensions in data cube |
0 |
9248 |
Fri, 28 August 2020 20:10 By: Jack Yang |
PDF render options By: sam va on Wed, 07 March 2012 |
21 |
30800 |
Fri, 28 August 2020 13:50 By: Mir Rafiquddeen |
Eclipse Birt - How to group dimensions in data cube Eclipse Birt - How to group dimensions in data cube |
0 |
8578 |
Thu, 27 August 2020 19:58 By: Jack Yang |
Eclipse Birt - Sub Total row cannot be applied on the last dimension Eclipse Birt - Sub Total row cannot be applied on the last dimension |
0 |
7885 |
Thu, 27 August 2020 17:36 By: Jack Yang |
Grouped bar chart with overlayed bars |
0 |
1311 |
Tue, 25 August 2020 17:20 By: Lada Rudnitckaia |
creating barcodes in BIRT Designer |
6 |
6917 |
Wed, 19 August 2020 01:46 By: Marco Lopes |
Report Layout printout in PDF not same issue Report Layout printout in PDF is different when compare the local PC with server client environment |
2 |
2649 |
Mon, 17 August 2020 09:57 By: Pick Luan Lau |
Count rows in Birt Doubt about comands |
3 |
3134 |
Sat, 15 August 2020 00:29 By: Isaac Manolo |
Embedded scripts does not work when Run->View Report->as PDF Script and PDF |
8 |
2252 |
Thu, 13 August 2020 20:23 By: Elizabet Gonzalez |
2D Datamatix barcode using iText 2D Datamatix barcode using iText |
0 |
1119 |
Thu, 13 August 2020 20:12 By: Len Burt |
Using an IN clause on an integer with report parameter |
2 |
2494 |
Wed, 12 August 2020 06:54 By: Andrew Sivyer |
Table not Showing in Connected Oracle Database in BIRT Remote Oracle Database Successfully Connected to BIRT But Tables Are Not Showing |
1 |
2628 |
Tue, 11 August 2020 21:30 By: Thomas Gutmann |
Align on Decimal Point for Negative Numbers with Parentheses |
1 |
2689 |
Tue, 11 August 2020 21:19 By: Thomas Gutmann |
How to center table in generated html file and auto wrap text in table cell How to center table in generated html file and auto wrap text in table cell By: 丁 涛 on Tue, 23 June 2020 |
1 |
3118 |
Tue, 11 August 2020 21:02 By: Thomas Gutmann |
Spudsoft XLS Export incorrect height for first row of grouping |
1 |
2626 |
Tue, 11 August 2020 20:43 By: Thomas Gutmann |
Page Break Page Break adds additional page at the end |
1 |
1734 |
Tue, 11 August 2020 20:12 By: Thomas Gutmann |
OUT Of Memory Error Java Heap Spae Problem |
6 |
11821 |
Tue, 11 August 2020 20:03 By: Thomas Gutmann |
count table row details in a group count table row details in a group |
1 |
2840 |
Tue, 11 August 2020 19:59 By: Thomas Gutmann |
step by step process for making change to existing ADhoc report Not able to make changes to existing SF Adhoc report using Eclipse |
1 |
1784 |
Tue, 11 August 2020 19:43 By: Thomas Gutmann |
Regarding Merging of similar data using Table Group Merging of similar data using Table Group |
1 |
1687 |
Tue, 11 August 2020 19:39 By: Thomas Gutmann |
Expression Builder GUI |
2 |
4558 |
Tue, 11 August 2020 19:36 By: Mukund S |
How to parse JSON or XML files from database to create report |
1 |
2881 |
Tue, 11 August 2020 19:24 By: Thomas Gutmann |
Making Data Warehouse How to make a Data Warehouse in BIRT |
1 |
1944 |
Tue, 11 August 2020 19:18 By: Thomas Gutmann |
is a .project file necessary to open a BIRT .rptdesign file in Eclipse? |
1 |
4822 |
Tue, 11 August 2020 18:55 By: Thomas Gutmann |
The type of parameter "registrationId" is expected as "integer", not "java. BIRT 3.7.1 to 4.4.2 upgrade on tomcat server |
1 |
4042 |
Thu, 06 August 2020 22:52 By: Juned Topiwala |
Default Dynamic Parameter |
11 |
9341 |
Wed, 05 August 2020 19:51 By: Junichi Eto |
pdf generation / UTF-8 By: Eclipse User on Tue, 01 August 2006 |
3 |
6476 |
Tue, 04 August 2020 13:12 By: dmitry khotsko |
Security issues reported in Apache POI Security issues |
0 |
4522 |
Tue, 04 August 2020 06:39 By: Pradeep Vinod |
Birt_Viewer Deployment Unable to view test report of birt viewer. |
0 |
1633 |
Thu, 30 July 2020 15:20 By: karishma Malhotra |
I built BIRT against Eclipse 2020-06 BIRT 4.16.0 |
2 |
3392 |
Thu, 23 July 2020 14:32 By: Tanguy Laver |
Call Java method in Birt Report I would like to call a java method in rptdesign file in |
0 |
3277 |
Mon, 06 July 2020 16:17 By: Krina Mehta |
BIRT report data mismatch Data mismatch in BIRT and Maximo |
0 |
2326 |
Wed, 24 June 2020 11:50 By: Gaurav R |
Detail Table values is in 2nd page |
1 |
1175 |
Wed, 24 June 2020 10:07 By: Colin Sutton |
pdf custom font formating problem unicode bangli font is broken |
0 |
2738 |
Tue, 23 June 2020 11:33 By: fajle rabbi |
Unable to set character encoding for URL parameters for report |
1 |
5777 |
Thu, 18 June 2020 10:41 By: Roei Hanuka |
How birt handles Khmer text Birt can render PDFs containing Khmer text, but it looks like garbled characters |
1 |
802 |
Thu, 18 June 2020 06:55 By: Roei Hanuka |
Replace zero values with a custom string in a table with aggregated values ... |
1 |
1289 |
Wed, 10 June 2020 10:44 By: Catalin Florean |
Page Break based on row count of two Tables Dynamic page break based on row count of two tables |
0 |
2213 |
Wed, 10 June 2020 02:56 By: Charlton Benhur |
The Eclipse executable launcher was unable to locate its companion shared library Launch issue |
0 |
3042 |
Wed, 03 June 2020 18:21 By: Tom Sparks |
how to remove Null Value. how to remove Null Value. |
8 |
9207 |
Tue, 02 June 2020 07:21 By: Srikanth G |
Word 2013 can't render xml based docs correctly |
6 |
6030 |
Thu, 28 May 2020 10:25 By: Henning von Bargen |
BIRT - 4.9 release by when shall we expect the birt 4.9 release |
4 |
8079 |
Tue, 26 May 2020 20:09 By: Thomas Gutmann |
Use computed column to concatenate data set data |
9 |
14357 |
Tue, 19 May 2020 23:09 By: Onochie Ojekwe |
Show Windows Current User in BIRT Report on TOMCAT Server |
0 |
1530 |
Tue, 19 May 2020 17:05 By: Kamlesh Chaudhari |
Aggregation Option to get nth data |
2 |
1160 |
Tue, 19 May 2020 13:46 By: Bryan Leow |
How meter chart is being used in BIRT? What are the data to be passed How data set mapped to meter chart |
1 |
2144 |
Tue, 19 May 2020 13:28 By: Bryan Leow |
Birt Viewer change hidden parameter in thread/concorrent application |
0 |
1550 |
Tue, 19 May 2020 10:53 By: Eduardo Vasconcelos |
Proper Separator Expression for Concatenated Computed Column with Multiple Data |
0 |
1714 |
Mon, 18 May 2020 00:28 By: Onochie Ojekwe |
How to create bar chart out of pie chart? (one bar, split by x axis entries) |
0 |
1868 |
Fri, 15 May 2020 12:12 By: Bryan Leow |
Java-Version-Compatibility |
2 |
2148 |
Fri, 15 May 2020 04:52 By: Andreas Hasselberg |
Highlight duplicate rows in the report |
0 |
1687 |
Thu, 14 May 2020 22:26 By: Isaac Manolo |
Syntax for Adding Both Text and Parameter to Report Title Parameters |
2 |
969 |
Fri, 08 May 2020 16:53 By: MIke Thomas |
BIRT report - Create different footers for different pages in a group list |
1 |
79920 |
Thu, 07 May 2020 19:33 By: Larry Novida |
Header Data |
2 |
1440 |
Thu, 07 May 2020 19:29 By: Larry Novida |
Missing Report BIRT Viewer Missing Report BIRT Viewer |
0 |
1556 |
Thu, 07 May 2020 14:21 By: wind kurn |
Eclipse BIRT Server setup The reports developed in Eclipse birt have to be uploaded in a server for User management,Reports scheduling and Data refresh. |
0 |
1898 |
Sat, 02 May 2020 15:33 By: Praveen Abburi |
Eclipse RCP Dynamic help customization Eclipse RCP Dynamic help customization by registering topic with dynamic url on fly |
0 |
4487 |
Thu, 30 April 2020 05:23 By: sarath s |
Is there a way to upgrade POI in BIRT runtime 4.7+ Is there a way to upgrade POI in BIRT runtime 4.7+ |
1 |
3271 |
Wed, 29 April 2020 19:33 By: Lucas Santos |
Files data handling[Stored in Database as binary data] in birt Rendering File data stored in database as binary data |
0 |
5842 |
Tue, 28 April 2020 07:51 By: Ashok kumar Angadi |
BIRT report to group multiple columns Merging columns based on ID column |
0 |
6081 |
Tue, 28 April 2020 04:27 By: Shruthi nayak |
Area Chart v2.0.1 |
9 |
3229 |
Mon, 27 April 2020 20:57 By: Formula Swiss Germany |
Accessing Birt Elements |
5 |
5461 |
Fri, 24 April 2020 16:04 By: Nicole Cochems |
Birt 4.8 ignores height of empty table rows Birt 4.8 ignores height of empty table rows |
3 |
3097 |
Thu, 23 April 2020 20:35 By: ivkina Mising name |
Conditional check failure outputs a "-2" instead of failing the report Conditional check failure outputs a "-2" instead of failing the report |
0 |
2590 |
Mon, 20 April 2020 18:16 By: rameez chowdhury |
Browser Issues using Birt Reports |
1 |
4518 |
Sat, 18 April 2020 02:17 By: Bryan Leow |
multiple data sets in data cube |
2 |
13713 |
Fri, 17 April 2020 09:10 By: Bryan Leow |
Which is faster: having one dataset for all charts or one dataset per chart? |
0 |
7792 |
Thu, 16 April 2020 08:45 By: Bryan Leow |
Using my own JAR file in BIRT seems impossible BIRT JAR file |
0 |
7752 |
Wed, 15 April 2020 08:09 By: Laurent Boutet |
dates By: Artek on Tue, 07 September 2004 |
3 |
30687 |
Mon, 13 April 2020 16:13 By: Eclipse User |
Hyperlink from one table to another table in BIRT report |
1 |
4533 |
Mon, 13 April 2020 15:23 By: Vijayalakshmi laxman |
question about design |
0 |
9653 |
Mon, 13 April 2020 15:15 By: Fumiko Bowen |
How can i filter a data in column which should be case insensitive |
0 |
9593 |
Sat, 11 April 2020 20:42 By: Akash Singh |
Sending Rendered BIRT Report via Email By: Eclipse User on Tue, 21 September 2010 |
6 |
13516 |
Sat, 11 April 2020 08:33 By: Dhanesh G |
Java heapspace Java heapspace error for 1.5 to 5 lak records |
0 |
4721 |
Wed, 08 April 2020 14:20 By: selva Mani |
birt report engine unable to run jar of birt report project |
0 |
4846 |
Wed, 08 April 2020 10:11 By: kanchan kachare |
[solved] Parameter Marker in FROM clause |
2 |
1681 |
Tue, 07 April 2020 07:51 By: Bryan Leow |
auto adjustment cell format |
0 |
4795 |
Mon, 06 April 2020 21:53 By: CLAUDIOMIRO WALTER |
2020-03 Release for Report Developers. Binding Column Alias names from multiple TSV flat files into a single chart |
0 |
5346 |
Mon, 06 April 2020 19:25 By: david moran |
How to Generate Spreadsheet with Multiple Worksheets (Tabs) Generate BIRT Spreadsheet with Multiple Spreadsheets |
2 |
1448 |
Mon, 06 April 2020 16:46 By: MIke Thomas |
Conditional Formatting of Dynamic Text produces the conditional format of only on statement for all values |
1 |
1875 |
Wed, 01 April 2020 03:49 By: Colin Sutton |
Display Consolidated data in the Last page of BIRT report |
0 |
3226 |
Tue, 31 March 2020 16:42 By: Vijayalakshmi laxman |
Generate a Distinct Table for Each Element in Parameter Array Given an array parameter, how can i generate a table for each element? |
2 |
5940 |
Tue, 31 March 2020 15:01 By: andy rush |
More than one Data Cubes in report do not work after migrating to Birt 4.8.0 Migration to Birt 4.8.0 |
0 |
2789 |
Wed, 25 March 2020 00:07 By: Durgesh Singh |
Unable to design a report using side by side tables and bar chart |
0 |
903 |
Fri, 20 March 2020 21:23 By: Jaideep Harsulkar |
where to find coreapi.jar, modelapi,jar, engineapi.jar |
4 |
5522 |
Fri, 20 March 2020 15:42 By: Nagarjun Kalivarapu |
Passing sub report totals to expressions |
6 |
6996 |
Thu, 19 March 2020 19:04 By: John Woolliscroft |
Page Break Issue birt engine is not applying page breaks automatically |
4 |
1095 |
Wed, 18 March 2020 11:00 By: chandrakanth padakandla |
How to avoid executing queries |
0 |
2203 |
Tue, 17 March 2020 07:52 By: Oscar Utrilla |
Display Values in single row instead of multiple rows |
7 |
5338 |
Mon, 16 March 2020 13:33 By: Anupam Nayak |
params["parameterName"].displayText returns "null" |
1 |
2088 |
Mon, 16 March 2020 10:45 By: dmitry khotsko |
LTR unicode (\u200E) get print in pdf There is unicode LTR (\u200E) in my text which is invisible chacrter but it gets print in pdf reports. |
0 |
1813 |
Mon, 16 March 2020 06:46 By: Muhammad Faisal |
PAGE BREAKS IN ADHOC REPORT CREATED IN MAXIMO PAGE BREAKS IN ADHOC REPORT CREATED IN MAXIMO |
0 |
2020 |
Sun, 15 March 2020 23:29 By: Mustafa Sabir |
How to tackle overflow scenario in stub for check stock that needs the check to be printed in middle By: Sid B on Fri, 13 March 2020 |
0 |
1271 |
Fri, 13 March 2020 19:26 By: Sid B |
Page number and date range Page number and parameter |
1 |
931 |
Fri, 13 March 2020 07:06 By: dmitry khotsko |
BiRT 4.5.0 runtime Platform.createFactoryObject returns null |
5 |
10977 |
Thu, 12 March 2020 18:48 By: Juned Topiwala |
PDF Pagebreak Problems How to break inside instead of before on long row content? |
9 |
17339 |
Wed, 11 March 2020 08:31 By: dmitry khotsko |
Passing parameters from Maximo to eclipse BIRT report Passing parameters from Maximo to eclipse BIRT report |
0 |
6470 |
Thu, 05 March 2020 17:12 By: Arjun gi |
how to create one table with two master pages? |
0 |
1377 |
Thu, 05 March 2020 08:56 By: dmitry khotsko |
How to pass connection to a drill through hyperlik? |
0 |
5598 |
Wed, 04 March 2020 13:14 By: Rodrigo Oliveira |
Chart errors when x value within one month version 4.8 upgrade causes chart to error out |
1 |
726 |
Tue, 03 March 2020 20:00 By: Stephen Kriesten |
BIRT ECCN number BIRT US Export control number |
0 |
2940 |
Thu, 27 February 2020 12:05 By: Amit Srivastava |
How to retrieve query value to Dynamic Text on Master Page Help with Birt 4.2.2 |
0 |
3197 |
Thu, 27 February 2020 09:37 By: Juan Gonzalez |
Multiple tab in excel report |
2 |
4044 |
Thu, 27 February 2020 06:35 By: yogita chaudhari |
Hyperlink/bookmark not working |
26 |
13849 |
Wed, 26 February 2020 16:02 By: Vijayalakshmi laxman |
Hyperlink not working as intended |
0 |
3253 |
Mon, 24 February 2020 07:24 By: Teja Nanduri |
Conditional Labels for Value (Y) series |
9 |
8965 |
Fri, 21 February 2020 21:13 By: Thrivikram Chamala |
bar chart not showing chart if data is missing values EVERE: null org.eclipse.birt.chart.exception.ChartException at org.eclipse.birt.chart.reportitem.ChartReportItemPresentationBase.onRowSets By: k p on Fri, 21 February 2020 |
0 |
4545 |
Fri, 21 February 2020 01:37 By: k p |
Conditional Hyperlink in BIRT Report |
2 |
1780 |
Wed, 19 February 2020 02:14 By: Vijayalakshmi laxman |
specific Persian font is not applied to excel reports problem with a specific Persian font for reports with excel output |
0 |
4653 |
Tue, 18 February 2020 11:29 By: razieh hafizi |
Images render in viewer and in HTML, but not PDF Can't render images when exporting to PDF |
0 |
4795 |
Thu, 13 February 2020 23:39 By: Karl Forsyth |
Set scale radar chart BIRT 2.6.0 Radar chart |
0 |
4775 |
Thu, 13 February 2020 14:31 By: Bruna Leal |
Check Box |
2 |
2332 |
Thu, 13 February 2020 10:32 By: Emanuele Spatola |
Selectively control spacing between HTML list items <ul><li> Styling HTML lists |
0 |
4751 |
Wed, 12 February 2020 21:58 By: Karl Forsyth |
2 |
916 |
Wed, 12 February 2020 21:56 By: Karl Forsyth |
Mosquitto 1.5 Client disconnect and broker freezes By: Eclipse User on Mon, 10 February 2020 |
0 |
3330 |
Mon, 10 February 2020 11:43 By: Eclipse User |
Does BIRT 2.2 support "named" parameters of data sets? |
4 |
1563 |
Fri, 07 February 2020 21:41 By: Smith Clarkson |
Value Inside Bar |
1 |
735 |
Thu, 06 February 2020 14:40 By: Eric Davis |
Collating Reports |
2 |
1218 |
Tue, 04 February 2020 20:14 By: andy rush |
4.9 BIRT does not run BIRT dead on arrival for 2019-06 |
10 |
194526 |
Mon, 03 February 2020 16:12 By: Thirumal m |
Birt 431 :multi select parameter How to add a multi select parameter |
1 |
2532 |
Sun, 02 February 2020 04:35 By: Nitin Dahyabhai |
How to set value for depending parameters in <birt:parameterPage> tag. setting parameter inside <birt:parameterPage> |
0 |
1461 |
Thu, 30 January 2020 15:52 By: sandip Mohapatra |
Java heap filling up with java.io.DeleteOnExitHook The memory is accumulated in one instance of "java.util.LinkedHashMap" loaded by "<system class loader>" |
1 |
66834 |
Thu, 23 January 2020 22:44 By: Frank van der Aa |
help tying my ODA into the report designer UI |
72 |
29875 |
Wed, 22 January 2020 02:16 By: Eclipse User |
Script: conditional formating of a lot of cells Please help me understand BIRT |
0 |
60692 |
Tue, 21 January 2020 14:50 By: Christian Kirchmair |
missing birt osgi runtime feature on the 2019-12 update site |
1 |
7299 |
Tue, 21 January 2020 14:19 By: Abhishek Chakraborty |
Problem with percentage calculation Newbie with stupid question |
3 |
2531 |
Fri, 10 January 2020 10:40 By: smk developer |
Birt 4.7/4.8 throw warnings with Java 9/10 |
5 |
5221 |
Sat, 04 January 2020 19:05 By: Kevin Rahe |
right to left sheets of birt excel report making an excel report sheet direction right to left |
0 |
2614 |
Sat, 04 January 2020 08:34 By: razieh hafizi |
Adding Column to Table |
2 |
12886 |
Tue, 31 December 2019 12:59 By: Jeff Kish |
How to save report to excel or pdf silently in server or client PC By: cbr125x on Tue, 06 September 2011 |
19 |
34750 |
Tue, 24 December 2019 02:58 By: Tejaswini Sonar |
Need help to disable multi-sheet export in XLSX format |
0 |
622 |
Mon, 23 December 2019 10:08 By: Dave At Work |
birt-runtime fails to start afer context reload birt-runtime fails to start after context reload |
0 |
599 |
Sun, 22 December 2019 20:40 By: Azat Usmanov |
Manage font Change font for PDF output |
0 |
767 |
Wed, 18 December 2019 11:37 By: Maria Sole Ieraci |
birt generating severe log for null parameters JDBCException: Cannot set preparedStatement null value |
0 |
3451 |
Wed, 18 December 2019 08:32 By: razieh hafizi |
how to generate multiple pdfs with birt how to generate multiple pdfs with birt |
0 |
2635 |
Tue, 17 December 2019 16:27 By: dorra mansouri |
Creating a batch job that runs multiple BIRT reports and exports to PPTX New to batch jobe in BIRT |
0 |
2630 |
Mon, 16 December 2019 20:49 By: Thomas Taylor |
task.setParameterValue |
9 |
14910 |
Mon, 16 December 2019 14:17 By: Andy K |
Hit OOM (java.lang.OutOfMemoryError) Hit OOM (java.lang.OutOfMemoryError) |
0 |
4282 |
Wed, 11 December 2019 05:48 By: Kai Ding |
0 |
3812 |
Wed, 11 December 2019 05:47 By: Kai Ding |
Repost Hide a row in the Header Page based on the value in teh datat set. Logo does not change based on the employees company |
0 |
4177 |
Tue, 10 December 2019 19:57 By: Sunny Ko |
File attachment How to attach a file in Birt report |
0 |
4034 |
Mon, 09 December 2019 19:45 By: Sameer Mathur |
BIRT REPORT AS INLINE ATTACHMENT Need to send the data in Email Body through BIRT Report |
0 |
1081 |
Thu, 05 December 2019 10:51 By: Harikrishnan G |
Birt viewer axis.jar axis.jar security problem |
0 |
2256 |
Fri, 29 November 2019 03:02 By: Chris Huang |
Master Page footer height depending on report parameter |
1 |
5657 |
Thu, 28 November 2019 11:44 By: Raphaël Renneau |
Unable to display Hindi characters in a BIRT PDF report Unable to display Hindi characters in a BIRT PDF report: Localization does not seem to work |
0 |
2068 |
Thu, 28 November 2019 06:54 By: Anisha Jaiswal |
BIRT Report Viewer in Windows Installing and configuring the report viewer to run on a windows 10 box |
0 |
2060 |
Thu, 28 November 2019 03:54 By: Evan Kontos |
Date formatting |
0 |
3080 |
Wed, 27 November 2019 16:35 By: Steve Brown |
Problem with date params start/end date params are one hour off By: A N on Thu, 08 December 2011 |
8 |
6729 |
Mon, 25 November 2019 17:23 By: Jonathan Cabral |
Cross Tab Subtotal Question Cross Tab subtotal to be at the top row instead of bottom row |
1 |
2244 |
Mon, 25 November 2019 11:48 By: Joy Islam |
Splitting cross tab header cell into multiple columns |
0 |
3877 |
Wed, 20 November 2019 16:57 By: Alex Davidson |
How to get the projects folder from in a script? By: Eclipse User on Tue, 01 November 2011 |
3 |
2836 |
Tue, 19 November 2019 08:24 By: Emanuele Spatola |
create Data Source with .csv Data Source |
1 |
2867 |
Mon, 18 November 2019 09:40 By: Jerry Cruise |
External Scripts |
5 |
4677 |
Fri, 15 November 2019 14:19 By: Emanuele Spatola |
Generate xlsx report using birt template and .csv file. Need to Generate a xlsx report using birt template that consumes .csv file data |
0 |
2471 |
Fri, 15 November 2019 06:22 By: santhosh ks |
HowTo read a textfile wwith javascript By: Eclipse User on Wed, 27 February 2008 |
3 |
3966 |
Thu, 14 November 2019 17:28 By: Emanuele Spatola |
vertical alignment vertical alignment |
0 |
2151 |
Tue, 12 November 2019 15:20 By: Marcel D |
How to determine difference between Dates in time in BIRT Eclipse How to determine difference between Dates in time |
0 |
2218 |
Wed, 06 November 2019 20:20 By: George Liatsidis |
How detect if a group is split by break page Birt two column reports |
0 |
1991 |
Mon, 28 October 2019 21:51 By: Georman Calderon |
BIRT is not working with eclipse 2019-09 |
1 |
5868 |
Mon, 28 October 2019 08:59 By: Stefan Weiser |
how prevent users from establishing a manual excel report |
0 |
1824 |
Sun, 27 October 2019 20:15 By: bensam22 bensam22 |
Gadget grouping on a column |
0 |
1778 |
Sun, 27 October 2019 12:59 By: Mihaela Marculescu |
Eclipse Report Viewer does not pick up changes in jsp files |
0 |
1338 |
Thu, 24 October 2019 14:52 By: Blind Brown |
How to hide csv icon from NavigationbarFragment.jsp for some specific reports Hide csv icon from specific reports. |
1 |
3558 |
Wed, 23 October 2019 07:56 By: Ed Merks |
BIRT Error "The property editor is not available." Property Editor |
0 |
8000 |
Mon, 21 October 2019 16:07 By: Steve Mising name |
Should I expect performance problems when aggregating on a scripted data source? |
0 |
8229 |
Mon, 21 October 2019 09:16 By: Paul Ramsden |
Spudsoft Excel Emitter documentation? Where can I find documentation on how to control the Spudsoft Excel emitter output? |
0 |
9793 |
Sat, 19 October 2019 20:29 By: James Clark |
Problem with date parameters "Cannot set the date value (2019-10-17 00:00) to parameter 1" |
0 |
10748 |
Thu, 17 October 2019 12:02 By: kaltoum hajoui |
Hiding a Crosstab Row Header |
0 |
8729 |
Wed, 16 October 2019 18:38 By: Robert Goff |
Missing plugins when exporting Eclipse e4 RCP Application containing Birt (Eclipse 2019-3) |
0 |
5877 |
Tue, 15 October 2019 09:47 By: Tom Brandl |
BIRT is not working with Eclipse 2019-06 |
5 |
35858 |
Mon, 14 October 2019 08:20 By: Marian Zaplatynski |
cross tab performance report crashes or takes more than 20 mins |
0 |
1883 |
Fri, 11 October 2019 21:59 By: mohamed rashdan |
Birt Backgroud Image Can we use blob type data from database as backgroundImage? |
0 |
17412 |
Tue, 08 October 2019 04:07 By: nay kyi than win |
BIRT 3.7 Repeat group header after pagebreak for DOC export |
0 |
17806 |
Mon, 07 October 2019 09:57 By: Nicholas Nichols |
How to fill an Array or ArrayList and use it in a query (Select IN) |
0 |
20043 |
Wed, 02 October 2019 15:04 By: Emanuele Spatola |
Cannot view report Preview |
1 |
4491 |
Tue, 01 October 2019 19:03 By: Gideon Engelbrecht |
Download Location of BIRT Viewer Toolkit |
11 |
10295 |
Tue, 01 October 2019 10:41 By: Ayusha Malviya |
[SOLVED] Cannot get the type for parameter: 1 Error in Data Sets |
5 |
10444 |
Fri, 27 September 2019 07:42 By: Emanuele Spatola |
