Topic |
Replies |
Views |
Last message |
Search disabled The Search function of this forum has been disabled, as it is currently the target of abuse. We apologize for the inconvenience. |
crosstab row headers Birt crosstab row headers using deapi |
0 |
6823 |
Thu, 04 February 2016 08:35 By: Himanshu Salgaonkar |
Print background image with browser print function Background image is not printed but should be |
0 |
6316 |
Thu, 04 February 2016 07:31 By: Stefan Seitz |
New to Cross tab - group sort order on a parameter Dynamically set or toggle group sort order for a cross tab ble |
3 |
2472 |
Wed, 03 February 2016 17:28 By: Russell Bateman |
cross tab show/hide grouping level not working |
0 |
5806 |
Wed, 03 February 2016 05:28 By: shekhar laad |
Implement a birt report on an image |
0 |
5160 |
Mon, 01 February 2016 12:33 By: Anuradha Kadurugasyaya |
Implement a birt report on an image Need to implement a birt report which is shown as in the image. |
0 |
4905 |
Mon, 01 February 2016 12:21 By: Anuradha Kadurugasyaya |
View Reports Is it possible to view reports within birt in read only or get the report out of birt and into another programme to view? like an addon? |
0 |
5086 |
Mon, 01 February 2016 09:45 By: ivo anusic |
Password Password not working |
1 |
1342 |
Fri, 29 January 2016 15:35 By: Eric Rizzo |
Report viewer bug(?) with ecore ODA driver |
0 |
4485 |
Fri, 29 January 2016 14:36 By: Lutz Wrage |
Unable to print image on Excel output in BIRT 3.7.1 Unable to print image on Excel output |
4 |
7641 |
Fri, 29 January 2016 04:15 By: Praveena Thangavel |
Integration Of birt reports with asp.net |
1 |
1811 |
Wed, 27 January 2016 14:36 By: Russell Bateman |
Last value of column in crosstab |
0 |
4816 |
Wed, 27 January 2016 12:16 By: MARGUET John |
String To Date String To Date Conversion |
1 |
5545 |
Wed, 27 January 2016 11:13 By: JP Redro |
Even when the status of renderTask is success, content of html file is not complete It is taking time to populate the html file after rendering it |
0 |
4542 |
Wed, 27 January 2016 10:14 By: Sravani Kambhampati |
Joint DataSet Parameter issue with Joint Dataset |
3 |
2385 |
Wed, 27 January 2016 09:15 By: JP Redro |
Bar chart x-axis labels changed to letters after upgrade |
8 |
9628 |
Tue, 26 January 2016 12:08 By: Abhishek Chakraborty |
how to make footer in BIRT how to make footer in BIRT |
0 |
5029 |
Tue, 26 January 2016 11:33 By: wanchalerm popee |
Linked Image not showing Signature images from a db filed not showing |
0 |
4889 |
Mon, 25 January 2016 23:49 By: Marquie BOard |
BIRT Documentation BIRT User's Manual |
2 |
1446 |
Thu, 21 January 2016 19:43 By: Eric Rizzo |
One Customer ID and Multiple Order IDs, Items, and Amounts How to display Customer ID only once with multiple order IDs, Items, and amounts |
0 |
5240 |
Thu, 21 January 2016 12:40 By: Shin Imai |
Execution time problem |
1 |
2998 |
Thu, 21 January 2016 12:35 By: alain alain |
Trying to add an image programmatically |
1 |
5466 |
Thu, 21 January 2016 07:49 By: Waseem Farooqui |
Custom ODA DataSet getting ResultSet columns by name not position Currently having difficulty determining the property(ies) to set to make PreparedStatement use column names |
1 |
4894 |
Wed, 20 January 2016 15:13 By: Jaeda Berry |
BIRT Dynamic Text Syntax Dynamic Text Syntax |
0 |
5371 |
Tue, 19 January 2016 18:57 By: Rocky Watson |
BIRT Barchart for SWT using chartwithaxes for 1000 entries How to create a barchart with 1000 entries in SWT composite |
0 |
5360 |
Tue, 19 January 2016 13:05 By: Abhishek Chakraborty |
SalesInvoice.rptdesign example from birt-viewer setup throws "Can not open the report archive.& |
0 |
6153 |
Mon, 18 January 2016 10:42 By: Dmitry Lukyanov |
Unable to save older BIRT reports with latest BIRT plugin |
2 |
2736 |
Mon, 18 January 2016 08:34 By: Anirban Lahiri |
LiClipse and Birt gives java.awt.HeadlessException error Solution |
0 |
3349 |
Fri, 15 January 2016 17:31 By: Hubert Pineault |
new version does not support older version the rpt filed designed in older version doesn not support newer version |
9 |
15886 |
Thu, 14 January 2016 10:09 By: Anirban Lahiri |
Parameterized report and parameter display when running the report how to display a report parameter when running? |
5 |
3125 |
Tue, 12 January 2016 06:14 By: Prasanna Rathinam |
Sum problem Totals Summing Problem |
0 |
4750 |
Mon, 11 January 2016 14:56 By: JP Redro |
Customising HTML Emitter |
0 |
5028 |
Mon, 11 January 2016 09:41 By: Nishant Mintri |
Maven dependency problem for org.milyn:flute |
2 |
6263 |
Fri, 08 January 2016 21:35 By: Quincy Campbell |
How to remove parameters in script |
0 |
5671 |
Fri, 08 January 2016 08:17 By: Cherie Ballinger |
Join by multiple data sets at runtime Join by multiple data sets at runtime |
1 |
1832 |
Thu, 07 January 2016 17:20 By: Jerry Sheets |
report app with Mongo DB |
2 |
1697 |
Thu, 07 January 2016 13:18 By: Rajarshi Chakravarty |
My first BIRT report - Not appearing when run from Eclipse |
1 |
2918 |
Wed, 06 January 2016 20:35 By: Larj Java |
Re: Integration of BIRT with D3 and AMChart- Urgent Help Required urgent help required |
3 |
5177 |
Wed, 06 January 2016 11:05 By: Stefan Uebe |
How to expand background color of cell to height of table row? How to expand background color of cell to height of table row? |
1 |
2481 |
Wed, 06 January 2016 07:52 By: Albert Bihler |
Get birt version as a variable |
0 |
4734 |
Tue, 05 January 2016 17:30 By: Felipe Oviedo |
Display a time duration in seconds in HH:MM:SS format Seconds value to hh:mm:ss in BIRT Report Designer v2.5.2 |
0 |
5536 |
Tue, 05 January 2016 13:05 By: Michel Aalders |
Passing date parameter to birt report via url Passing date parameter through url is not fetching data, no error message |
1 |
3206 |
Mon, 04 January 2016 21:40 By: Jerry Sheets |
BIRT LIcense |
0 |
5519 |
Mon, 04 January 2016 08:43 By: Praseetha sm |
Passing date parameter to birt report through url Passing date parameter through url is not working |
0 |
5223 |
Mon, 04 January 2016 04:31 By: Mafsul Maru |
POJO Data Set and HttpClient POJO Data Set and HttpClient |
0 |
6245 |
Tue, 29 December 2015 11:37 By: Gniewko Ostrowski |
How to pass the value of one data set into the another dataset? |
28 |
33844 |
Sun, 27 December 2015 12:27 By: Yogesh Patil |
How to use Spudsoft emitter and its Userproperties to export formula in birt report exporting? Want to export excel formulas, so that when i export my report to excel, the formula gets executed and shown in excel sheet. |
2 |
6742 |
Thu, 24 December 2015 08:22 By: Javier Ww |
report designer 4.5 all-in-one errors can not run birt report designer 4.5 all-in-one |
0 |
5490 |
Wed, 23 December 2015 11:36 By: tdr ruttenberg |
Unable to integrate BIRT report in JAVA Web Project and deploy on tomcat message /RallyLogin/frameset description The requested resource is not available. |
0 |
5581 |
Tue, 22 December 2015 13:54 By: Nikita Aggarwal |
Problem with Instantiation of XSSF POI objects java.lang.SecurityException: class "org.apache.poi.util.PackageHelper when trying to instantiate XSSF POI objects |
0 |
7946 |
Mon, 21 December 2015 10:50 By: Pedro HERNANDEZ |
Convert varchar to integer for group totals Need to convert currency-formatted string to integer to use aggregation |
0 |
6508 |
Sat, 19 December 2015 07:35 By: Jeff Stouse |
BIRT Reports won't render with Internet Explorer 11 |
0 |
4714 |
Fri, 18 December 2015 18:00 By: Norm Merrill |
The new column name or alias txt_"campo" is already used by the column at index 17 Erro ao executar o relatório no BIRT Report |
1 |
2171 |
Thu, 17 December 2015 13:42 By: leon oliveira |
No Report Template By: Eclipse User on Mon, 28 July 2008 |
3 |
2084 |
Wed, 16 December 2015 20:25 By: Lei Zhang |
Remove the null values in a multi-value listbox By: Scroon on Tue, 28 June 2011 |
8 |
17961 |
Wed, 16 December 2015 08:41 By: Denis Godunov |
Can't see all the tables? I am dealing with a large DB and can't see all the tables when creating a data set |
2 |
3590 |
Tue, 15 December 2015 08:11 By: Tim Amphlett |
DB Connection Issue Password limits... |
1 |
3881 |
Mon, 14 December 2015 10:04 By: Tim Amphlett |
Excel Tables in spreadsheet export with Spudsoft Emitter Help with creating an Excel table in spreadsheet export with spudsoft emitter |
0 |
5293 |
Fri, 11 December 2015 22:46 By: Michael Snowden |
Automatically passing parameters to XML data source |
0 |
5383 |
Fri, 11 December 2015 11:50 By: John Schmidt |
StockEntry problem in version 4.5.0 StockEntry problem in version 4.5.0 |
0 |
5281 |
Fri, 11 December 2015 11:47 By: Michael Addlesee |
BIRT REPORT BIRT REPORT By: shaz ck on Thu, 10 December 2015 |
1 |
1060 |
Thu, 10 December 2015 08:03 By: Ed Merks |
Not all results show up in query Data Results |
0 |
4064 |
Wed, 09 December 2015 14:40 By: Keith Stramler |
Using BIRT Runtime Package in 64-bit Windows 7 with Java 8 Looking for straightforward setup sequence |
1 |
1704 |
Wed, 09 December 2015 13:10 By: Richard A. Polunsky |
footer on last page only |
9 |
5214 |
Tue, 08 December 2015 09:25 By: Thirumal m |
Eclipse Birt Report 4.3 |
1 |
1287 |
Mon, 07 December 2015 09:08 By: Ed Merks |
BIRT Release Notes URL Unable to locate release notes for BIRT versions |
1 |
3745 |
Sat, 05 December 2015 12:05 By: donino donino |
Weighted Average Error Weighted Average causes error in 2.5.1 |
0 |
4344 |
Fri, 04 December 2015 19:45 By: Eric Shaw |
Variable problem Variable problem |
0 |
4225 |
Wed, 02 December 2015 21:04 By: Hugo Araujo |
Issue with XLS data source BIRT throwing an exception while trying to open the Excel sheet |
0 |
4281 |
Wed, 02 December 2015 14:28 By: Hinduja Ichapuram |
Cross tab in BIRT Need to use Grand total outside the cross tab |
0 |
4357 |
Wed, 02 December 2015 06:22 By: Sakshi Bhandari |
WSDL data set for BIRT Unable to obtain results from Weather service |
0 |
5548 |
Wed, 02 December 2015 01:03 By: Randy Leonard |
Problem display component Line Chart |
0 |
4717 |
Tue, 01 December 2015 10:39 By: ahmed rouissi |
Passing parameters via URL |
1 |
3963 |
Sat, 28 November 2015 20:45 By: Jerry Sheets |
MS SQL db only returning first 100 tables Data set builder only shows first 100 tables |
0 |
2125 |
Thu, 26 November 2015 17:30 By: Curtis Zieseniss |
runtime problem after migration runtime crash after migration from birt 3.7.2 on eclipse indigo to birt 4.4.2 on eclipse kepler |
0 |
2239 |
Thu, 26 November 2015 15:55 By: alexandre mevel |
How to check if parameter was set (Birt 2.1.1) By: Eclipse User on Tue, 10 October 2006 |
5 |
21310 |
Wed, 25 November 2015 13:04 By: Md. Atequer Rahman |
PERCENTSUM does not work? By: B. Z. on Wed, 25 November 2015 |
0 |
3805 |
Wed, 25 November 2015 09:16 By: B. Z. |
How to add JDBC driver to a BIRT project |
0 |
5008 |
Wed, 25 November 2015 01:08 By: Neil Wang |
Crosstab interpolate data so graph 'connects the dots' problems with calculation based on measures in crosstab |
0 |
3410 |
Mon, 23 November 2015 08:59 By: Jeroen Bosch |
Reporting Wizard and report perspective is not showing in eclipse Luna I installed reporting tool using software update site http://download.eclipse.org/birt/update-site/4.4/ |
0 |
4818 |
Sat, 21 November 2015 12:40 By: Neeraj Gautam |
Difficulties to export BIRT report designer as a product... ...since Luna 4.4.1 and with Mars.1 |
2 |
1891 |
Fri, 20 November 2015 12:45 By: Laurent Le Moux |
Escaping + Birt Security |
0 |
3007 |
Thu, 19 November 2015 12:39 By: Thomas P. |
Line Break with Emails |
0 |
3510 |
Thu, 19 November 2015 10:22 By: Thomas P. |
pageNumber and totalPage in PDF are wrong pageNumber and totalPage in PDF are wrong |
0 |
3827 |
Mon, 16 November 2015 19:21 By: Neil Wang |
Report as ods not usable (missing elements, line height to small) |
0 |
3571 |
Mon, 16 November 2015 15:21 By: Christian Meister |
Charts sometimes showing as blank |
1 |
5709 |
Fri, 13 November 2015 17:59 By: Dan Hlavenka |
Correct usage of parameters in BIRT report |
0 |
3772 |
Fri, 13 November 2015 13:22 By: Trevor James |
Grouping Issue Grouping is not working with XML data source in BIRT 4.3.1 |
0 |
3791 |
Fri, 13 November 2015 09:02 By: JP Redro |
Designer Formatting text |
0 |
3347 |
Thu, 12 November 2015 23:22 By: augustin Boumba |
Empty Rows displaying in report |
4 |
7066 |
Thu, 12 November 2015 21:23 By: Trevor James |
Background Image on Header in Master page Background Image is not getting displayed when deployed to server |
10 |
5061 |
Thu, 12 November 2015 18:35 By: Preetha S |
Integrating d3 chart in BIRT d3 graph is not displayed when viewed as pdf and other formats except html |
7 |
3503 |
Thu, 12 November 2015 09:57 By: donino donino |
Getting error when running BIRT report Exported Tririga report running problem in BIRT |
0 |
4747 |
Thu, 12 November 2015 07:44 By: Ankush Chaudhary |
Nulls and empty strings lat |
0 |
4973 |
Wed, 11 November 2015 18:05 By: Tharpa Roberts |
The value of the property "Key expression" is required. |
1 |
5778 |
Wed, 11 November 2015 16:41 By: Tharpa Roberts |
Error Installing BIRT 2.5.2 on Galileo on MAC Fails Can't install BIRT on Galileo on Mac though Eclipse runs fine |
0 |
2992 |
Wed, 11 November 2015 05:18 By: Stephen Musoke |
How to retrieve username in parameter default value? |
1 |
4276 |
Tue, 10 November 2015 11:29 By: Amanulla Khan |
64bit installation? |
1 |
4078 |
Mon, 09 November 2015 11:51 By: Justin none |
How to add a column for computing the resolution rate in cross table? crosstab add column computing |
0 |
4662 |
Sun, 08 November 2015 09:23 By: Albert Yao |
X axis grouping in Bar Chart dynamic x axis grouping |
6 |
4939 |
Fri, 06 November 2015 21:40 By: Preetha S |
Library to create reports on ERP data |
0 |
4258 |
Fri, 06 November 2015 12:28 By: Aryans King |
Unable to add values based on status Unable to add values in TKSTATUS.STATUSTRACKING based on group (status) |
0 |
4418 |
Fri, 06 November 2015 12:19 By: Jagath Nair |
PDF not working in birt |
0 |
4464 |
Fri, 06 November 2015 09:30 By: swaroop eswara |
Generating letters in PDF format for multiple records Generating letters in PDF format for multiple records |
1 |
1892 |
Thu, 05 November 2015 20:16 By: Jerry Sheets |
Script code to count the number of report parameters |
3 |
1793 |
Thu, 05 November 2015 15:27 By: yoovraj khullar |
Table - layout |
0 |
4356 |
Thu, 05 November 2015 14:55 By: Maria Smith |
known Issues when using batik 1.8 with birt |
0 |
4602 |
Thu, 05 November 2015 09:49 By: Thomas P. |
Webviewer on server Stackoverflow, Eclipse viewer works great |
1 |
1911 |
Wed, 04 November 2015 15:54 By: Garey Smiley |
Highlight cell in crosstab causes stackoverflow in webviewer but not in eclipse |
0 |
4828 |
Wed, 04 November 2015 15:53 By: Garey Smiley |
Expression text for mongo aggregate query in BIRT What is the syntax of the expression text for an aggregate query on mongo db? |
0 |
4731 |
Wed, 04 November 2015 05:35 By: Kanj Narayan |
How to manipulate certain values from a multi-value parameter |
0 |
5648 |
Tue, 03 November 2015 18:44 By: Scott Williams |
How to reference the string of a multi-value parameter |
2 |
4351 |
Tue, 03 November 2015 18:41 By: Scott Williams |
Maps Component |
0 |
4600 |
Tue, 03 November 2015 08:10 By: Stefan Bernsdorf |
IBM TRIRIGA BIRT Preferences - Not Displaying in Eclipse Preferences after install |
0 |
7238 |
Mon, 02 November 2015 19:54 By: Trevor James |
Problems with Preview |
2 |
4716 |
Mon, 02 November 2015 13:13 By: Anderson Teixeira |
Wildcards in Parameters How to replace multiple * with % |
0 |
5061 |
Mon, 02 November 2015 09:52 By: Ian Pike |
How to get the value of a cell in a table by BIRT API? |
0 |
6720 |
Thu, 29 October 2015 18:14 By: Albert Yao |
Table of Contents How to add a table of contents in the report |
2 |
5209 |
Thu, 29 October 2015 16:17 By: Perry King |
Date Comparison Date issue |
0 |
6825 |
Thu, 29 October 2015 13:02 By: JP Redro |
Beginners Question about BIRT |
0 |
5386 |
Thu, 29 October 2015 12:08 By: Matthias N |
BIRT 4.5 Engine not working BIRT 4.5 Engine By: bas 123 on Tue, 27 October 2015 |
0 |
5774 |
Tue, 27 October 2015 13:23 By: bas 123 |
XML ERROR in Workbook Setting when opening exported excel a error like: XML ERROR in Workbook Setting REASON: Bad Value FILE: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Report-42.xls GROUP: Names TAG: NamedRange ATTRIB: Name VALUE: R2A is showing when I try to open |
5 |
7423 |
Mon, 26 October 2015 21:50 By: Michael Csuti |
Custom Report Wizards |
0 |
5249 |
Mon, 26 October 2015 17:48 By: Scott Lewis |
Get rid of this toolbar under filename? How do you close this toolbar? |
0 |
5061 |
Mon, 26 October 2015 14:25 By: Megg Gawat |
mechanism to show or hide layers in BIRT BIRT |
2 |
1292 |
Mon, 26 October 2015 14:24 By: Megg Gawat |
big speed difference eclipse/ external jar - Platform.startup(config) / task.run() very slow report generating: eclipse 10 sec / external jar 441 sec By: dome G. on Fri, 09 October 2015 |
1 |
4656 |
Mon, 26 October 2015 13:10 By: dome G. |
Integrating D3.js in Birt D3.js with Birt |
0 |
6042 |
Mon, 26 October 2015 11:58 By: swaroop eswara |
BIRT // Hive// Unable to execute aggregate functions Unable to execute select min(cpu) from testcpuinfo group by reportname |
0 |
4564 |
Fri, 23 October 2015 04:07 By: aashish kumar |
Browser-side BIRT Charts BIRT Charts rendered in-browser |
0 |
6337 |
Thu, 22 October 2015 23:05 By: RealName Mising name |
Report rendering issue 3.7.1 vs 4.3.1 Report working in 3.7.1 doesn't work in 4.3.1 |
0 |
6871 |
Thu, 22 October 2015 15:30 By: Mukesh Somani |
not a valid month error in query with date parameter mm.yyyy |
0 |
7442 |
Thu, 22 October 2015 13:57 By: youssef idrissi |
How to link two reports Displaying details for an entry |
1 |
1311 |
Wed, 21 October 2015 18:28 By: Eric Rizzo |
Exception when ResultSet is empty Cannot fetch the next data row, org.eclipse.birt.report.data.oda.jdbc.JDBCException: Cannot move down to next row in the result set. com.ibm.db2.jcc.c.SqlException: Invalid operation: result set clo |
4 |
35392 |
Tue, 20 October 2015 20:24 By: Kevin Rahe |
org.eclipse.birt.report.engine.executor.ApplicationClassLoader Memory Leak Receiving Out Of Memory Error in BIRT Reports Application |
3 |
4781 |
Fri, 16 October 2015 05:32 By: Richard Riviere |
BIRT 4.5 XLSX Export using ExcelEmitter.TemplateFile XLSX Export works in Designer not with Runtime |
0 |
5725 |
Wed, 14 October 2015 18:32 By: Pamela White |
How to display zero value How to display zero value in the bar chart value series. By: A R on Wed, 09 May 2012 |
19 |
12827 |
Wed, 14 October 2015 16:15 By: Keerthi Nandakumar |
XML values not enlisting Only top-line XML values are enlisted excluding the child |
0 |
3456 |
Wed, 14 October 2015 14:21 By: Shivkumar Birnale |
BIRT connection with Hive, can we have single data source for all reports Single Data SOurce for multiple .rptdesign reports |
1 |
2505 |
Wed, 14 October 2015 11:13 By: charles candy |
Birt Report and hypenation |
0 |
3619 |
Wed, 14 October 2015 07:42 By: Thomas P. |
How to set style to an element based on its value dynamically? |
2 |
2846 |
Tue, 13 October 2015 07:58 By: Manikandan Arunachalam |
no protocol + OdaException + Birt |
1 |
5945 |
Mon, 12 October 2015 18:35 By: Carlos Andres Garcia Garcia |
PDF renders differently from Birt Designer and Runtime |
1 |
4222 |
Mon, 12 October 2015 02:51 By: Jomar Romero |
New to BIRT Scripting creating table filters on onClick events |
0 |
3552 |
Thu, 08 October 2015 19:38 By: Robert Johnston |
How to write RPTDOC file in chunk |
2 |
2845 |
Thu, 08 October 2015 08:22 By: Alberto Moreno |
Caused by: java.lang.ArrayIndexOutOfBoundsException when using birt 4.2.1 |
0 |
4669 |
Thu, 08 October 2015 06:16 By: GOKULAKRISHNAN MUTHAN |
opening rptdesign in eclipse 3.7.1 seeing xml instead of designer opening rptdesign in eclipse 3.7.1 seeing xml instead of designer |
2 |
5471 |
Tue, 06 October 2015 14:16 By: stan teitelbaum |
BIRT Report - Gantt Chart: Opening a Modal popup on Mouse Click |
0 |
2684 |
Fri, 02 October 2015 18:01 By: Gauzy Gz |
Missing spaces and tabulator in the report output in odt-format Missing spaces and tabulator in the report output in odt-format |
0 |
3901 |
Fri, 02 October 2015 11:07 By: Johann Waber |
*Space* Delimited Flat File ? How to ? Scripting ? By: Tom G on Thu, 01 October 2015 |
0 |
3913 |
Thu, 01 October 2015 17:11 By: Tom G |
Convert web report written in PHP to BIRT |
0 |
3342 |
Wed, 30 September 2015 14:36 By: Paul Thomas |
Tririga Birt Reporting How to enable Eclipse Logs for Tririga Birt Reporting |
0 |
3899 |
Wed, 30 September 2015 14:28 By: Vaibhav Nigam |
Service Parameters are not displayed in BIRT DataSet Creation Wizard Service Parameters are not displayed while creating BIRT DataSet for the Webservice DataSoucre |
0 |
3732 |
Wed, 30 September 2015 10:57 By: Agalya Anbazhahan |
Generation report Memory leak |
0 |
3745 |
Wed, 30 September 2015 08:49 By: tulfier tulifer |
How to search for multiple values when a particular parameter is selected When a value is selected, I need the query to search on that value plus 1-3 other pre-defined values |
5 |
2097 |
Tue, 29 September 2015 20:01 By: Jerry Sheets |
Does the BIRT engine issue queries concurrently (for a single report)? |
0 |
4003 |
Tue, 29 September 2015 19:03 By: John Edo |
Direct Print renders blank report Direct Print renders blank report |
0 |
4132 |
Tue, 29 September 2015 14:54 By: Kimberlee Miller |
May I use a chart with only one row data? draw pie chart, bar chart |
3 |
4995 |
Tue, 29 September 2015 13:34 By: martin gordon |
Label Position Change position dynamically |
4 |
3166 |
Tue, 29 September 2015 10:17 By: silvia dominguez |
BIRT: OUTPUT COLUMNS unchanged even after replacing query Unable to refresh output columns in BIRT |
1 |
2914 |
Sun, 27 September 2015 16:11 By: aashish kumar |
Unable to get All Table Name in DataSet after successfull connection to Oracle DB I am unable to find few tables in DataSet |
2 |
2896 |
Sun, 27 September 2015 16:04 By: aashish kumar |
Conditioning sub-totals based on # of rows in a group |
0 |
4391 |
Thu, 24 September 2015 14:39 By: Missing name Mising name |
Reg: Unable to create dynamic report dataset are not getting changed |
0 |
4449 |
Thu, 24 September 2015 04:48 By: kshirod mishra |
Connecting to Oracle Database Via OJDBC Slow I am trying to run a report that hits an Oracle Database through an OJDBC connection. |
0 |
4449 |
Wed, 23 September 2015 20:36 By: Brian Runyon |
Make everything in a dataset only show one letter? |
3 |
1084 |
Wed, 23 September 2015 14:39 By: Megg Gawat |
Cannot generate xlsx using birt runtime version 4.4.2 Using the birt runtime to generate xlsx file. |
0 |
5160 |
Tue, 22 September 2015 18:08 By: yusuf nazir |
Poll: Itemnum below the barcode when displayed vertically in BIRT 232 getting truncated at the bottom Rotate Text with Barcode.The Text (itemnum) below barcode gets truncated at bottom |
0 |
8607 |
Mon, 21 September 2015 18:55 By: fathima rizwana |
OdaException OdaException |
0 |
4397 |
Mon, 21 September 2015 09:54 By: Franziska Rosenberg |
Using row[] or <VALUE-OF> data in an HTML 'Text' Field How do I use an if-statement for a row value in an HTML text field? |
0 |
5324 |
Fri, 18 September 2015 04:09 By: Chantal Hadamek |
Unable to access vars from beforeRendering in nested barchart getPersistentGlobalVariable returns null |
2 |
1724 |
Thu, 17 September 2015 10:45 By: Jay Doggett |
Replacin null value with string '--' in all data elements of the grid |
0 |
4045 |
Thu, 17 September 2015 08:43 By: Aleksander Kruecken |
Creating Multi Sheets Report in BIRT How can I create a report having Detailed Sheet and also Summary Sheet(Based on the summary of Detailed Sheet) |
0 |
4125 |
Thu, 17 September 2015 07:26 By: Suvarnni M V |
Setting field separators for flat files By: Eclipse User on Thu, 11 August 2005 |
2 |
1707 |
Wed, 16 September 2015 04:28 By: aashish kumar |
How to fix position of Export icon in Eclipse view |
4 |
4816 |
Wed, 16 September 2015 04:10 By: Ian Wark |
[Ecore ODA driver] access to attributes in Ecore conform model using birt data sets |
0 |
3893 |
Tue, 15 September 2015 10:46 By: smaoui asma |
Birt Runtime 4.4.2 source Jar Maven Repository Some Source code missing in Source jar from Maven Repository |
0 |
7114 |
Mon, 14 September 2015 16:14 By: Christoph Henrici |
Compute report title without running entire report? |
0 |
3990 |
Mon, 14 September 2015 14:32 By: John Edo |
Sample XML Settings and Row/Column Mapping If now specific data source is used the row and column mapping of a data set cannot be displayed even though Sample XML Settings are set |
0 |
4444 |
Mon, 14 September 2015 11:39 By: Andreas Hahne |
retrieve the contents of a column of the dataset with Javascript |
0 |
4608 |
Mon, 14 September 2015 08:41 By: prue IIBO |
Changing the font size with Java API |
0 |
4163 |
Mon, 14 September 2015 07:14 By: Carlo Alberto Catarinicchia |
Connect report to sqllite How can i connect a report runtime to a sqlite database which is on my tablet |
0 |
2841 |
Sat, 12 September 2015 14:42 By: Necmetdin Karademir |
java.lang.NullPointerException, at org.eclipse.birt.chart.factory.Generator.getRowExpressions By: Eclipse User on Thu, 24 January 2008 |
1 |
6106 |
Sat, 12 September 2015 08:24 By: Eclipse User |
Excel and OpenOfficeSpreadSheet is Crashing when There are 1,50,000 Rows |
2 |
4568 |
Fri, 11 September 2015 04:18 By: Suvarnni M V |
Scatter Chart Add dynamic margins to the vertical axis of a graph |
0 |
4747 |
Tue, 08 September 2015 11:28 By: prue IIBO |
How to change the browser to the execution of BIRT reports |
0 |
5127 |
Mon, 07 September 2015 12:47 By: prue IIBO |
Calling a report BIRT from a Java application I can't call a report from a Java application |
0 |
3401 |
Sun, 06 September 2015 10:13 By: Tomas Cerda |
Access LDAP via JNDI |
0 |
4097 |
Thu, 03 September 2015 14:51 By: Juliane Harbarth |
Library Explorer not found |
0 |
4098 |
Thu, 03 September 2015 12:46 By: Ronald Rensing |
Bar Charts Showing values on each bar on the Graph |
3 |
1657 |
Thu, 03 September 2015 08:05 By: prue IIBO |
can i connect BIRT reporting tool to two sql servers? can i connect BIRT reporting tool to two sql servers? By: mhd mhd on Wed, 02 September 2015 |
1 |
1161 |
Thu, 03 September 2015 06:43 By: Colin Sutton |
Report Parameters Cascading Parameters |
2 |
1120 |
Wed, 02 September 2015 13:49 By: latronda Washington |
Change font in the PDF Where and how to change the font to make it available in the PDF |
0 |
4712 |
Wed, 02 September 2015 12:04 By: Marika Kunze |
javax.imageio.IIOException: I/O error writing PNG file javax.imageio.IIOException: I/O error writing PNG file |
0 |
6021 |
Wed, 02 September 2015 07:32 By: Jatin Gupta |
DataSet Issue Cannot get BIRT to process DataSet |
0 |
3680 |
Tue, 01 September 2015 09:34 By: SR Mising name |
Impossible to use BIRT |
1 |
1739 |
Tue, 01 September 2015 06:01 By: Ed Merks |
Unable to sort - Solved By: Alex Ca on Tue, 01 September 2015 |
0 |
3265 |
Tue, 01 September 2015 00:55 By: Alex Ca |
Dynamic BIRT Report Data Change is not happening on selection |
0 |
3354 |
Mon, 31 August 2015 08:49 By: kshirod mishra |
how to download birt runtime |
0 |
3138 |
Sun, 30 August 2015 08:37 By: huang jacky |
How to setup the Birt report's timeout ? |
0 |
3652 |
Fri, 28 August 2015 08:58 By: spark xue |
Altering Properties of Crosstab Grouping DataItem |
0 |
3263 |
Thu, 27 August 2015 17:20 By: Paul Cooper |
Selectively Enable Huperlink on an Attribute value in BIRT Can anyone help me out in selectively enabling Hyperlink which drills down to another report in BIRT reporting? Like for example, in my initial BIRT report, I have two attributes. ATTR1 and ATTR2. Sa |
0 |
3345 |
Thu, 27 August 2015 10:32 By: Varun Vemuganti |
