Topic |
Replies |
Views |
Last message |
Maintain http session web bundle How to maintain http session alive when update web bundle |
1 |
3189 |
Fri, 25 May 2012 08:22 By: Glyn Normington |
Read only access control for virgo console access control required for virgo console for different users |
1 |
3045 |
Fri, 25 May 2012 08:19 By: Glyn Normington |
Virgo hangs while starting after upgrade from M2 to M4 Virgo hangs while starting after upgrade from M2 to M4 |
4 |
7145 |
Fri, 25 May 2012 07:56 By: taher mosbah |
Scoped plan with EclipseLink runs into problems Switching from unscoped to scoped results in errors |
1 |
4420 |
Wed, 23 May 2012 18:10 By: Rich Mayfield |
Use of plain old Eclipse Plugins with Virgo Tooling Unable to load manifest either in Virgo Server or Eclipse Launcher |
6 |
4807 |
Wed, 23 May 2012 15:12 By: Miles Parker |
log cookies |
10 |
14555 |
Tue, 22 May 2012 05:30 By: karthik elavan |
Logback DBAppender in Virgo. How configure DBAppender in serviceability.xml |
5 |
10033 |
Tue, 22 May 2012 03:16 By: Dmitry Axenenko |
Spring MVC Web-bundle no context created |
2 |
4182 |
Mon, 21 May 2012 13:26 By: Johan Eriksson |
HELP ABOUT Spring STS 3.0 with virgo tomcat server |
1 |
4197 |
Mon, 21 May 2012 08:42 By: taher mosbah |
3.5.0M4 Blueprint extender failing to create context |
3 |
3556 |
Mon, 21 May 2012 04:18 By: Arief Bastian |
Bundle deployment questions |
1 |
2772 |
Sat, 19 May 2012 06:41 By: Borislav Kapukaranov |
Weird bundle export problem (manifest being overwritten) |
5 |
4312 |
Fri, 18 May 2012 14:44 By: Simon Watson |
Resolving uses violations |
2 |
5005 |
Fri, 18 May 2012 08:58 By: Rich Mayfield |
Access rules in bundle dependencies which can't be changed |
1 |
4560 |
Fri, 18 May 2012 08:06 By: Glyn Normington |
Osgi bug in log4j prevents osgi unaware web-app from startup |
1 |
3975 |
Fri, 18 May 2012 08:04 By: Glyn Normington |
Can 'plan' be renamed to something more unique? Searching for plan-related topic would be much easier |
1 |
2411 |
Fri, 18 May 2012 08:01 By: Glyn Normington |
Unable to deploy bundle/plan with Virgo Tooling Unable to deploy bundle/plan with Virgo Tooling |
4 |
4930 |
Thu, 17 May 2012 01:51 By: Rich Mayfield |
Why does plan deplyment fails when uploading from the web console? The result of the last operation is: Deployment Error 'bundle 'test.dummy' version '[1.0.0, 2.0.0)' not found' |
4 |
2886 |
Wed, 16 May 2012 19:45 By: Marton Sigmond |
Issue with Version range in Import package latest bundle version packages not getting referred in other bundles when imported using version range. |
1 |
2090 |
Wed, 16 May 2012 14:09 By: Hristo Iliev |
Virgo hangs when stopping web bundle Virgo hangs when stopping web bundle using Spring DM, Apache Shiro and web filter |
1 |
3874 |
Tue, 15 May 2012 19:45 By: Roman Janusz |
Spring OSGI version in virgo 3.5.0.M4 |
3 |
2534 |
Tue, 15 May 2012 18:02 By: Mastah Naleh |
How to view bundle dependency graph on Virgo |
3 |
2640 |
Tue, 15 May 2012 08:19 By: taher mosbah |
Greenpages 2.4 not working Greenpages 2.4 not working |
17 |
8653 |
Mon, 14 May 2012 19:05 By: Thorsten Schlathölter |
Weird ClassNotFoundException |
2 |
4832 |
Mon, 14 May 2012 17:15 By: Eduardo Frazão |
Greenpages 2.5.0.RELEASE |
3 |
2633 |
Mon, 14 May 2012 16:50 By: Miles Parker |
[Tooling] Feedback on Default VM settings |
0 |
15615 |
Sat, 12 May 2012 01:15 By: Miles Parker |
Problems running Spring DM application in Virgo A Require-Bundle could not be resolved because of a uses directive conflict. Caused by missing constraint in bundle |
1 |
4605 |
Fri, 11 May 2012 13:23 By: Thorsten Schlathölter |
@Autowired doesn't work when trying to wire a service |
4 |
6172 |
Thu, 10 May 2012 16:54 By: taher mosbah |
TCCL Headache |
2 |
2263 |
Thu, 10 May 2012 15:34 By: Glyn Normington |
Virgo and binded ports How configure address for all of them? |
3 |
3615 |
Thu, 10 May 2012 14:33 By: Eduardo Frazão |
Want Virgo on CloudFoundry? |
2 |
10956 |
Thu, 10 May 2012 13:04 By: Glyn Normington |
How to change the value of LimitRequestFieldSize in virgo tomcat server |
4 |
7268 |
Thu, 10 May 2012 09:22 By: karthik elavan |
Problems loading ApplicatioContext file in a WAB |
11 |
14055 |
Thu, 10 May 2012 01:50 By: teresa tang |
Snaps Parent Application Context Not Loading |
3 |
4300 |
Wed, 09 May 2012 16:44 By: Paul Duffin |
JCE cannot authenticate provider installed as OSGi bundle |
3 |
15593 |
Wed, 09 May 2012 12:28 By: Glyn Normington |
Conflicts configuring EclipseLink with Virgo |
4 |
6694 |
Wed, 09 May 2012 10:23 By: taher mosbah |
Could not use repository chain in new virgo tool |
6 |
4526 |
Mon, 07 May 2012 07:03 By: George Zeng |
How to get EclipseRT/Virgo option back in New Server wizard (STS 2.9.1) |
4 |
4753 |
Sat, 05 May 2012 11:07 By: Barbara Rosi-Schwartz |
How to compensate for slow provisioning server |
3 |
3849 |
Fri, 04 May 2012 11:29 By: Barbara Rosi-Schwartz |
Help! Update virgo tool from sts2.91 and the plugin crashed |
4 |
2904 |
Fri, 04 May 2012 03:44 By: Miles Parker |
Dependent Applications |
7 |
3353 |
Thu, 03 May 2012 17:11 By: Johan Eriksson |
Bundle refresh in virgo 3.0.2 failed |
12 |
12936 |
Thu, 03 May 2012 14:33 By: Peter Mucha |
PAR project compiler error in virgo |
10 |
10754 |
Thu, 03 May 2012 07:24 By: karthik elavan |
Virgo 3.5.0.M04 released |
0 |
17035 |
Wed, 02 May 2012 08:37 By: Borislav Kapukaranov |
Error configuring application listener java.lang.ClassNotFoundException |
3 |
5135 |
Wed, 02 May 2012 05:14 By: tim zchina |
Weird in war file deployment exception |
1 |
4317 |
Tue, 01 May 2012 08:32 By: Glyn Normington |
trouble changing the greenpages sample to use hibernate |
30 |
29117 |
Mon, 30 April 2012 18:26 By: sriram ks |
Disable Automatic Fragment Resolution |
1 |
3148 |
Mon, 30 April 2012 14:01 By: Chris Frost |
Fail to load bundle from repository |
3 |
3033 |
Sat, 28 April 2012 18:05 By: Mastah Naleh |
Virgo 3.0.3.RELEASE |
0 |
15091 |
Fri, 27 April 2012 09:45 By: Glyn Normington |
Equinox Registry and Adapter factory Cannot deploy both org.eclipse.equinox.registry and org.eclipse.equinox.common |
1 |
4931 |
Fri, 27 April 2012 08:55 By: Florian Waibel |
Connecting to Virgo's JMX Unable to connect programmatically to Virgo's JMX using TCP port due to SunCertPathBuilderException |
1 |
7235 |
Thu, 26 April 2012 17:04 By: Violeta Georgieva |
virgo ide installation failed |
12 |
12484 |
Thu, 26 April 2012 15:39 By: Miles Parker |
Loading a vanilla war file fails until WABheaders=defaulted is set |
6 |
5039 |
Thu, 26 April 2012 13:28 By: Violeta Georgieva |
Maven repository for Virgo 3.0.0 artifacts |
5 |
5138 |
Wed, 25 April 2012 16:28 By: Violeta Georgieva |
unable to deploy roo 1.1.0 war on virgo web server 2.1.0 |
7 |
7525 |
Wed, 25 April 2012 16:25 By: Violeta Georgieva |
Activate simple logging for a bundle Logging for a bundle |
4 |
4514 |
Wed, 25 April 2012 12:23 By: Stefan Huber |
Virgo 3.5.0.M03 released The third Bondi milestone is out! |
2 |
4370 |
Tue, 24 April 2012 17:46 By: Violeta Georgieva |
Juno, Indigo, Helios..? |
0 |
15642 |
Mon, 23 April 2012 22:07 By: Miles Parker |
Developing with Virgo Using Maven/m2Eclipse |
1 |
2405 |
Fri, 20 April 2012 17:14 By: Miles Parker |
406 Not Acceptable Jackson JSON in Virgo Web Server By: Alexey on Mon, 06 December 2010 |
6 |
25411 |
Thu, 19 April 2012 09:17 By: rajkumar Mundel |
Failed to activate Greenpages Sample in Virgo 3.0.2 Failed to activate Greenpages Sample in Virgo 3.0.2 |
8 |
9764 |
Thu, 19 April 2012 07:58 By: Glyn Normington |
Eclipse Help for Virgo |
0 |
13578 |
Sat, 14 April 2012 17:36 By: Miles Parker |
Spring DM: No Catalina Service found |
9 |
6759 |
Fri, 13 April 2012 17:14 By: R Abreu |
OSGI reference Bean not found A referenced OSGI service cannot be injected with @Autowired |
4 |
18695 |
Fri, 13 April 2012 17:11 By: R Abreu |
Import-Package weird |
3 |
3968 |
Mon, 09 April 2012 07:57 By: Violeta Georgieva |
Fresh installation problem Dependency problem? |
3 |
4015 |
Fri, 06 April 2012 00:36 By: Miles Parker |
Empty bundle dependecies after upgrading VTS to 3.5.0.M2 |
15 |
11530 |
Thu, 05 April 2012 11:11 By: Jay Huang |
Embed Eclipse Virgo inside another application server |
9 |
6208 |
Wed, 04 April 2012 16:53 By: Paul Duffin |
CME Group Experience of Virgo |
0 |
12342 |
Wed, 04 April 2012 15:38 By: Glyn Normington |
Unable to find Library ( .libd ) file Error |
3 |
5015 |
Wed, 04 April 2012 10:28 By: Glyn Normington |
Why is there a uses conflict without disjoint ranges? |
1 |
3015 |
Tue, 03 April 2012 14:33 By: Glyn Normington |
Spring ORM Bundle - ClassNotFoundException javax.persistence.metamodel.Metamodel import missing on Virgo Provided bundle? |
2 |
4015 |
Tue, 03 April 2012 11:51 By: Eduardo Frazão |
Replacing OSGI bundles in the running environment |
1 |
2516 |
Mon, 02 April 2012 14:54 By: Glyn Normington |
Context Path issue with WAB |
2 |
2837 |
Sun, 01 April 2012 12:25 By: Obiwan Kenobi |
how to change virgo tomcat server character encoding |
7 |
6288 |
Sun, 01 April 2012 11:23 By: Frieder Heugel |
STS,Clud Foundry, and Virgo IDE |
1 |
2219 |
Wed, 28 March 2012 19:16 By: Chris Frost |
Virgo + Apache ACE? |
4 |
3963 |
Wed, 28 March 2012 17:57 By: Borislav Kapukaranov |
JDK 7 bundles? |
1 |
1814 |
Wed, 28 March 2012 17:26 By: Hristo Iliev |
Virgo web server(tomcat) 3.0.0 bundle failed to started |
11 |
13075 |
Wed, 28 March 2012 15:49 By: Violeta Georgieva |
Virgo server memory problem |
2 |
3632 |
Wed, 28 March 2012 09:43 By: karthik elavan |
Using logback in OSGI Bundle |
4 |
4655 |
Wed, 28 March 2012 04:57 By: saurabh chhajed |
ImportMergeException for aspectj |
3 |
3083 |
Tue, 27 March 2012 20:44 By: Piotrek De |
Cleaning up Virgo repository |
3 |
2946 |
Tue, 27 March 2012 07:38 By: Glyn Normington |
Virgo tomcat Server 3.0.2 uploading war file problem |
0 |
15387 |
Mon, 26 March 2012 06:12 By: karthik elavan |
Maven best practices discussion moved from https://bugs.eclipse.org/bugs/show_bug.cgi?id=329198 |
1 |
5135 |
Fri, 23 March 2012 08:24 By: Glyn Normington |
Log display command? |
2 |
2159 |
Thu, 22 March 2012 16:55 By: James Gartner |
Virgo White Paper |
0 |
12036 |
Thu, 22 March 2012 15:51 By: Glyn Normington |
Deploying EclipseRT bundles to Eclipse-embedded Virgo Tomcat doesn't work |
3 |
3490 |
Thu, 22 March 2012 08:09 By: Glyn Normington |
Servlet ClassNotFound exception |
4 |
6323 |
Tue, 20 March 2012 21:06 By: Violeta Georgieva |
Virgo 3.0.2 Released |
5 |
5280 |
Tue, 20 March 2012 20:58 By: Violeta Georgieva |
How to debug with Virgo |
3 |
2626 |
Tue, 20 March 2012 20:48 By: Miles Parker |
[tooling] Important Note re: Server Runtime Versions |
6 |
2952 |
Tue, 20 March 2012 20:45 By: Miles Parker |
Possible caching issue? |
7 |
3549 |
Tue, 20 March 2012 20:08 By: Miles Parker |
Accessing the kernel via telnet |
10 |
7877 |
Mon, 19 March 2012 21:09 By: James Gartner |
a problem about dependencies. |
1 |
1873 |
Mon, 19 March 2012 17:43 By: Violeta Georgieva |
Virgo tomcat web server OutOfMemoryError |
3 |
4862 |
Fri, 16 March 2012 10:35 By: Glyn Normington |
Deadlock detected |
12 |
12784 |
Fri, 16 March 2012 09:02 By: Glyn Normington |
Adding a custom command via gogo in Virgo 3 Unable to add custom command to shell |
5 |
4289 |
Wed, 14 March 2012 10:29 By: Sathyakumar Seshachalam |
Snaps-based app doesn't allow welcome files? |
2 |
3528 |
Tue, 13 March 2012 17:29 By: Jason Levine |
**RFC: Supporting PDE/Equinox bundles in Eclipse IDE |
0 |
12128 |
Mon, 12 March 2012 20:40 By: Miles Parker |
Move META-INF and lose Bundle Dependencies in Eclipse? |
4 |
5377 |
Mon, 12 March 2012 15:22 By: Jason Levine |
Virgo won't use Velocity 1.7.0, only 1.6.2 |
1 |
2294 |
Mon, 12 March 2012 15:21 By: Glyn Normington |
Is it possible to use Apache Felix instead of Equinox as the OSGi platform for Virgo? |
1 |
2056 |
Fri, 09 March 2012 10:05 By: Glyn Normington |
Say goodbye to Tooling Spring IDE Dependencies. |
5 |
3557 |
Fri, 09 March 2012 01:44 By: Leo Dos Santos |
Getting plug-in dependencies from server repository |
5 |
4716 |
Fri, 09 March 2012 01:43 By: Leo Dos Santos |
Is Virgo Tooling snapshot compatible with VTS 3.0.*? |
6 |
2967 |
Thu, 08 March 2012 04:42 By: Miles Parker |
virgo + springDM + custom Application Context Listener |
1 |
2618 |
Mon, 05 March 2012 09:04 By: Glyn Normington |
Class not found, export only problem |
1 |
2695 |
Fri, 02 March 2012 12:11 By: Hristo Iliev |
How to disable necessaries log stoped in virgo tomcat server |
1 |
3743 |
Fri, 02 March 2012 09:45 By: Glyn Normington |
Virgo Nano + p2 + profile |
2 |
3864 |
Thu, 01 March 2012 12:19 By: Mixa Alekseev |
Advice on solution architecture needed |
5 |
4056 |
Wed, 29 February 2012 12:39 By: Brian Williamson |
SpringDM - Exporting Spring Bean as Service - Problem with scope <bean scope="prototype" /> does not works |
5 |
4093 |
Tue, 28 February 2012 11:13 By: Eduardo Frazão |
Snaps issues with dispatchservlet mapped to (snap) root and separate resources folder (this makes it hard to get clean url's with Snaps) |
2 |
5004 |
Tue, 28 February 2012 02:25 By: Dmitry Sklyut |
Grails on VTS Constraint Issues |
16 |
14765 |
Tue, 28 February 2012 02:19 By: Dmitry Sklyut |
What's the difference between Virgo Tomcat and Virgo Jetty |
1 |
2893 |
Mon, 27 February 2012 12:55 By: Chris Frost |
Build Virgo Kernel 3.0.0.M04 in IDE |
6 |
10273 |
Mon, 27 February 2012 12:17 By: Glyn Normington |
Unable to build the Greenpages sample |
7 |
9371 |
Mon, 27 February 2012 12:10 By: Chris Frost |
Virgo issue java.lang.OutOfMemoryError |
3 |
2380 |
Fri, 17 February 2012 16:13 By: Hristo Iliev |
How to read kernel dumps |
3 |
2390 |
Fri, 17 February 2012 16:12 By: Barbara Rosi-Schwartz |
Error w/Spring 3.1.0.RELEASE in repository/usr w/Virgo Tomcat 3.5.0.M02 |
12 |
6208 |
Fri, 17 February 2012 13:49 By: Glyn Normington |
Bundle startup order in virgin VWS |
5 |
6092 |
Fri, 17 February 2012 10:26 By: Glyn Normington |
JMX Mbean registration and configuration artifacts |
1 |
3574 |
Fri, 17 February 2012 09:28 By: Glyn Normington |
Spring Security for Multiple Web Page How to connect spring security username/password between different web application |
1 |
14358 |
Fri, 17 February 2012 08:39 By: Glyn Normington |
Example of Embedding Kernel |
3 |
2422 |
Fri, 17 February 2012 00:56 By: Nick Baker |
Virgo 3.5.0.M02 released Second Virgo Bondi milestone available |
5 |
3422 |
Thu, 16 February 2012 14:57 By: Arief Bastian |
Using config artifacts for multiple envs |
7 |
3509 |
Thu, 16 February 2012 11:33 By: Barbara Rosi-Schwartz |
Spring Security on multiple bundles Illegal access while using Spring Security Authentification manager service. |
4 |
9124 |
Wed, 15 February 2012 06:18 By: Groovy Groovy |
Remote Virgo server sending a 404 |
3 |
2892 |
Tue, 14 February 2012 15:19 By: Glyn Normington |
Exporting bundle project uses incorrect MANIFEST.MF |
8 |
30689 |
Tue, 14 February 2012 06:12 By: Alexey Romanov |
greenpages 2.5.0 on Virgo 3.1.0 org.h2.Driver ClassNotFoundException org.h2.Driver not found by KernelBundleClassLoader |
8 |
8348 |
Tue, 14 February 2012 02:02 By: Miles Parker |
Virgo Server Tooling on STS 2.9.0.M1 works! and FYI Virgo tooling/IDE is only a separation of Virgo (/DM Server) stuff inside STS |
8 |
6416 |
Mon, 13 February 2012 23:02 By: Leo Dos Santos |
spring dm test startup failes By: malik on Sun, 12 February 2012 |
1 |
2039 |
Sun, 12 February 2012 13:24 By: Borislav Kapukaranov |
Virgo + Spring Security + EHCache Classloader issue |
7 |
9321 |
Fri, 10 February 2012 22:11 By: Paul Watson |
First Virgo SNAP with JSF Could not find backup for factory javax.faces.context.FacesContextFactory |
4 |
6549 |
Thu, 09 February 2012 11:22 By: Moacir Cardoso |
Running RAP on Virgo |
1 |
8296 |
Thu, 09 February 2012 09:11 By: Florian Waibel |
Latest IDE snapshot build? |
4 |
3842 |
Thu, 09 February 2012 02:58 By: Andrew Rootmann |
Blueprint - Can I use Apache Aries? Gemini Blueprint seems to cause some conflict on Virgo. Can I use Aries? |
3 |
3704 |
Tue, 07 February 2012 14:02 By: Glyn Normington |
Virgo and STS 2.7.2 STS 2.7.2 giving issues with dm-server tool 2.7.0.xx |
1 |
2970 |
Tue, 07 February 2012 08:21 By: Glyn Normington |
Virgo, Jetty 8 and WebSockets |
4 |
3148 |
Mon, 06 February 2012 20:45 By: Violeta Georgieva |
Running Virgo with the security manager |
2 |
3553 |
Mon, 06 February 2012 15:31 By: Barbara Rosi-Schwartz |
Eclipse Virgo Tooling and Use Repo Bundle added to repository/usr not showing in Repository tab of Virgo Tooling |
5 |
4929 |
Mon, 06 February 2012 15:22 By: Eduardo Frazão |
Attention Virgo builders: upgrade Ant |
0 |
13735 |
Wed, 01 February 2012 15:09 By: Glyn Normington |
Kernel not starting when launched from java program |
8 |
4308 |
Wed, 01 February 2012 14:00 By: Barbara Rosi-Schwartz |
Virgo & SecurityManager |
8 |
6117 |
Wed, 01 February 2012 09:10 By: Anton Kolmakov |
Existing Tomcat + OSGI + Spring |
1 |
2940 |
Wed, 01 February 2012 01:50 By: Hugues Malphettes |
Error @Autowired Service in Virgo |
10 |
5835 |
Mon, 30 January 2012 21:08 By: Dmitry Sklyut |
Virgo Tooling - Third party bundles Tooling, import packages from thirdy party bundles, that is not on the default repository |
6 |
4531 |
Mon, 30 January 2012 17:57 By: Eduardo Frazão |
Virgo Repository |
4 |
3049 |
Mon, 30 January 2012 09:17 By: Glyn Normington |
War File URL Virgo vs Jetty |
6 |
5565 |
Sat, 28 January 2012 00:25 By: Geoffry Roberts |
Class not found mystery |
8 |
8807 |
Fri, 27 January 2012 13:40 By: Hristo Iliev |
Maven plugin to deploy bundles to Virgo |
11 |
10236 |
Wed, 25 January 2012 17:47 By: Frieder Heugel |
FIRST GWT WAB Classpath problem java.lang.ClassNotFoundException |
8 |
4337 |
Wed, 25 January 2012 17:00 By: Moacir Cardoso |
Refresh OSGi bundles programmatically By: JP S on Mon, 23 January 2012 |
5 |
6514 |
Wed, 25 January 2012 08:47 By: Glyn Normington |
HOW-TO: Logging with the logback Consoleappender and/or custom appenders? java.lang.ClassNotFoundException: ch.qos.logback.core.Consoleappender |
1 |
5895 |
Tue, 24 January 2012 15:47 By: Lazar Kirchev |
CME Group and Virgo Reference users |
0 |
12675 |
Mon, 23 January 2012 14:42 By: Glyn Normington |
org.eclipse.virgo.kernel.deployer bundle is not started correctly |
5 |
6852 |
Fri, 20 January 2012 15:42 By: Glyn Normington |
Problema configuring virgo on eclipse Virgo Jetty Server starts but get 404 on http://localhost:8080 |
3 |
2746 |
Fri, 20 January 2012 15:37 By: Chris Frost |
Gradle : Bundlor plugin in Groovy Gradle : Bundlor plugin in Groovy |
10 |
7293 |
Fri, 20 January 2012 14:12 By: Chris Frost |
Working with Virgo and Hibernate |
6 |
4711 |
Thu, 19 January 2012 22:56 By: Dmitry Sklyut |
What bundles Should I use to work with Hibernate and Virgo? |
0 |
12707 |
Thu, 19 January 2012 17:06 By: Gabriel Afonso |
Questions regarding Regions/Subsystems, p2/OBR |
4 |
4721 |
Wed, 11 January 2012 22:41 By: Rafal Krzewski |
How to develop Spring Session Scope Beans |
3 |
7150 |
Mon, 09 January 2012 09:30 By: Carlos Salinas |
Using Virgo Snaps and Spring Interceptors |
5 |
4103 |
Fri, 06 January 2012 19:51 By: Gabriel Afonso |
Load jsp from another bundle OSGi Try to load jsp file from another bundle |
5 |
6138 |
Wed, 04 January 2012 16:35 By: Gabriel Afonso |
Virgo 2.1.1 and Blazeds 4.0 |
4 |
3067 |
Tue, 03 January 2012 09:27 By: Glyn Normington |
Virgo application server support |
1 |
2866 |
Tue, 03 January 2012 08:47 By: Glyn Normington |
Cannot connect to the user region of VTS 3.5M1 via remote SSH |
2 |
3131 |
Sun, 01 January 2012 10:26 By: Frieder Heugel |
Virgo 3.5.0.M01 released First Virgo Bondi milestone available |
0 |
12967 |
Thu, 29 December 2011 13:55 By: Borislav Kapukaranov |
Can't start greenpages.web-solution:2.4.0 in virgo-tomcat.3.0.2 |
3 |
4785 |
Thu, 29 December 2011 07:56 By: Mariano Eloy Fernández Osca |
Deploying webapp with Spring WebFlow Application fails to deploy with ClassNotFoundException |
1 |
5298 |
Tue, 27 December 2011 02:45 By: Marcelo Daniel |
Spring/Rest and OSGi HttpService |
3 |
5219 |
Mon, 26 December 2011 18:42 By: Chris Frost |
3.0.1 failed to build By: malik on Sun, 25 December 2011 |
4 |
3629 |
Mon, 26 December 2011 12:59 By: malik |
Console in virgo 3.0.2 |
2 |
2618 |
Fri, 23 December 2011 13:03 By: Vladimir Glushak |
listener (bind-method and unbind-method) bundle behavior when listened service leaves |
2 |
2654 |
Wed, 21 December 2011 17:02 By: C TRAN-XUAN |
how to export PAR/bundle with my own manifest bundle deployment By: will on Mon, 19 December 2011 |
1 |
2749 |
Mon, 19 December 2011 10:03 By: Glyn Normington |
Virgo Heap Dump |
2 |
3495 |
Mon, 19 December 2011 09:59 By: Glyn Normington |
Deploy war file Question about deploying a war file |
5 |
5976 |
Sat, 17 December 2011 10:16 By: karthik elavan |
NamespaceHandler |
1 |
2335 |
Fri, 16 December 2011 09:30 By: Glyn Normington |
faild to build org.eclipse.virgo.kernel.userregion |
5 |
3512 |
Fri, 16 December 2011 07:20 By: Violeta Georgieva |
Virgo IDE error: No value found for placeholder 'project.name' "Spring Tools-> Run the generation of MENIFEST.MF file" can not generate the MNIFEST.MF file correct. |
1 |
3348 |
Wed, 14 December 2011 10:53 By: Chris Frost |
userregionfactory failed to start By: malik on Thu, 01 December 2011 |
6 |
6994 |
Mon, 12 December 2011 13:40 By: Borislav Kapukaranov |
Virgo web server(tomcat) 3.0.1 Where is context.xml? |
3 |
4439 |
Mon, 12 December 2011 13:26 By: Percy Wang |
Virgo Scripts with cygwin support Virgo Scripts with cygwin support |
3 |
3532 |
Mon, 12 December 2011 10:33 By: Glyn Normington |
Uses violation |
10 |
7829 |
Fri, 09 December 2011 17:04 By: Glyn Normington |
ClassNotFoundException for javax.crypto class |
1 |
1998 |
Wed, 07 December 2011 14:11 By: Borislav Kapukaranov |
When will Virgo tooling be officially available for STS 2.8? Virgo STS 2.8 integration |
1 |
2179 |
Mon, 05 December 2011 10:10 By: Martin Lippert |
Virgo 3.0.1 startu failed error |
7 |
9801 |
Mon, 05 December 2011 09:27 By: Glyn Normington |
How to detect log4j config file in bundle fragment |
4 |
4361 |
Fri, 02 December 2011 15:52 By: Glyn Normington |
Install failed for bundle ### version '0.0.0'. Problem by bundle installation into Virgo server. |
5 |
5351 |
Fri, 02 December 2011 12:53 By: karthik elavan |
Is Virgo web container capable of using OSGI bundles? |
2 |
2324 |
Thu, 01 December 2011 18:27 By: Seref Arikan |
Virgo 3.0.1 greenpages 2.4 build problems in STS 2.8 Virgo 3.0.1 greenpages 2.4 build problems in STS 2.8 |
3 |
4097 |
Mon, 28 November 2011 16:56 By: Jay Hamilton |
First page load takes a long time By: Preethi on Tue, 22 November 2011 |
5 |
4325 |
Fri, 25 November 2011 15:26 By: Preethi |
Unable to satisfy dependencies of bundle 'com.springsource.org.apache.xerces' |
11 |
13203 |
Thu, 24 November 2011 16:05 By: Glyn Normington |
Snaps 3.0.1.RELEASE maven repo |
2 |
2349 |
Thu, 24 November 2011 15:19 By: attila Mising name |
Problems registering two servlets in a WAB |
14 |
13902 |
Thu, 24 November 2011 15:04 By: Violeta Georgieva |
Dynamic class loading in fragment How to load dynamically new classes in context |
1 |
2356 |
Thu, 24 November 2011 06:57 By: TorTukiTu Mising name |
ClassNotFoundException when using bundled spring-context-support Unable to find a class embedded inside a war By: Balaji on Thu, 17 November 2011 |
10 |
6596 |
Tue, 22 November 2011 10:11 By: Balaji |
Bundlor 1.1.0.M02 released |
0 |
13744 |
Fri, 18 November 2011 13:19 By: Chris Frost |
Issue with a servlet that uses RSA code |
3 |
5798 |
Fri, 18 November 2011 13:15 By: mcoss Missing name |
