Topic |
Replies |
Views |
Last message |
Snaps Host using Spring Using Spring MVC in Snaps Host |
13 |
13851 |
Wed, 19 December 2012 04:11 By: Dmitry Sklyut |
How to disable the Admin Web Console |
1 |
2420 |
Tue, 18 December 2012 22:26 By: Chris Frost |
Can virgo(tomcat) hot deploy a web bundle which is in a plan |
2 |
2468 |
Tue, 18 December 2012 14:43 By: George Zeng |
Exact meaning of 'services in use' don't see an osgi service reference at runtime |
1 |
2690 |
Tue, 18 December 2012 14:26 By: Glyn Normington |
Creation of logback LoggerContext within library fails |
1 |
3576 |
Tue, 18 December 2012 14:18 By: Glyn Normington |
Virgo Web Bundle Help Configuring a Web Bundle with Spring and without Maven |
2 |
4616 |
Tue, 18 December 2012 14:15 By: Seth Helstrip |
3.6.0.RC1 available |
0 |
10010 |
Mon, 17 December 2012 11:43 By: Borislav Kapukaranov |
java.lang.NoClassDefFoundError: javax/management/ObjectName |
3 |
4515 |
Wed, 12 December 2012 20:54 By: daniel marthaler |
3.6.0.M05 released |
0 |
9826 |
Wed, 12 December 2012 17:20 By: Borislav Kapukaranov |
Hot deployment of plan bundle |
4 |
3182 |
Wed, 12 December 2012 10:41 By: Glyn Normington |
Spring Annotation Driven Controller in different bundles |
2 |
11181 |
Wed, 12 December 2012 05:40 By: shiv khillar |
Blueprint Cyclic Dependency |
2 |
3759 |
Fri, 07 December 2012 11:18 By: Glyn Normington |
Table LISTING not found in greenpages example Submit Query search in greenpages generates SQL error By: Glennn on Tue, 14 June 2011 |
6 |
8405 |
Thu, 06 December 2012 23:06 By: Chuck Williams |
Managing Your Target Platform with Virgo Tooling |
3 |
4928 |
Wed, 05 December 2012 15:59 By: GianMaria Romanato |
Fat client remoting with Virgo looking for example code |
0 |
10908 |
Tue, 04 December 2012 07:23 By: Erik Vande Velde |
Shutdown Virgo programmatically |
3 |
2824 |
Fri, 30 November 2012 14:10 By: Eduardo Frazão |
javax.net.ssl and jersey dependency can't find bundles export jersey and javax.net.ssl |
1 |
6471 |
Thu, 29 November 2012 14:15 By: Dmitry Sklyut |
Spring security on Virgo |
1 |
2739 |
Wed, 28 November 2012 23:03 By: Rigas Grigoropoulos |
Spring MVC - Register New Controllers programatically |
6 |
4837 |
Wed, 28 November 2012 19:46 By: Eduardo Frazão |
Virgo 3.6.0.M04 |
0 |
10225 |
Wed, 28 November 2012 16:36 By: Glyn Normington |
Virgo Snaps: Templating via Fillter |
3 |
3108 |
Wed, 28 November 2012 12:47 By: Markus Schmailzl |
SpringDM Managed Service List is not updated with new services |
1 |
2253 |
Mon, 26 November 2012 13:46 By: Eduardo Frazão |
Servlet Filter cannot be found in classpath other than WEB-INF/... Exception starting filter Test1Filter java.lang.ClassNotFoundException: |
2 |
7733 |
Mon, 26 November 2012 13:33 By: Thorsten Schlathölter |
edit files from a staged bundle |
0 |
10747 |
Thu, 22 November 2012 15:19 By: attila Mising name |
Virgo tools put test classes in staging dir add/remove of a module takes test classes too |
0 |
11078 |
Thu, 22 November 2012 12:22 By: Erik Vande Velde |
Spring framework 3.2.0.RC1 available for testing with Virgo |
0 |
11423 |
Wed, 21 November 2012 15:22 By: Glyn Normington |
Write log message in a single file - virgo - common - logging |
2 |
4149 |
Wed, 21 November 2012 06:30 By: TRAN Lap |
Exception when trying to use spring namespace handler in virgo |
7 |
6707 |
Tue, 20 November 2012 11:24 By: Yousef Fadila |
cipango on virgo jetty server |
0 |
11447 |
Tue, 20 November 2012 11:22 By: Yousef Fadila |
II18N message from diffrent bundels How to pick messages from applicationResources_<Lang>.properties of diffrent bundels |
0 |
10907 |
Mon, 19 November 2012 15:38 By: Amit Saluja |
service lookup fails with plan based deployment service lookup fails with plan based deployment |
4 |
3738 |
Mon, 19 November 2012 13:58 By: Erik Vande Velde |
Listener for bundle consuming services |
3 |
3027 |
Mon, 19 November 2012 10:09 By: Glyn Normington |
Enhancement propal for Integration tests |
5 |
3367 |
Fri, 16 November 2012 14:02 By: Glyn Normington |
Virgo + Hibernate problems Problem in springsource repository |
3 |
3059 |
Fri, 16 November 2012 02:03 By: Rigas Grigoropoulos |
Virgo tooling : Bundle dependencies broken once changed MANIFEST.MF of a installed bundle Virgo tooling : Bundle dependencies broken once changed MANIFEST.MF of a installed bundle |
2 |
2230 |
Thu, 15 November 2012 18:23 By: Leo Dos Santos |
[SOLVED] Using the embedded Tomcat for JNDI and DataSources A possible approach to using Tomcat support for JDBC datasources and few related questions |
10 |
11785 |
Thu, 15 November 2012 15:17 By: Thomas Kölling |
How to deploy maven web project to Virgo? What's the most practical way to do this? |
1 |
3884 |
Thu, 15 November 2012 03:00 By: Leo Dos Santos |
Dependencies tab missing for mavenized par project manifest editor incomplete after adding a virgo par facet |
1 |
4476 |
Thu, 15 November 2012 02:07 By: Leo Dos Santos |
Virgo tooling: issues with hot deploy to server in Servers view |
6 |
5373 |
Thu, 15 November 2012 01:37 By: Leo Dos Santos |
Virgo vs Hibernate vs Joda |
0 |
11759 |
Wed, 14 November 2012 16:09 By: Seth Helstrip |
Blueprint problem after moving from 3.5.0.M03 to 3.5.0.RELEASE or 3.6.0.M03 |
4 |
6123 |
Tue, 13 November 2012 08:56 By: Glyn Normington |
Monitoring Directories Using Spring Integration Trying to monitor a directory in a Virgo web app. None of the Spring Integration examples seem to work |
4 |
4475 |
Fri, 09 November 2012 21:42 By: David Bohlin |
Books you should read about OSGi |
5 |
5750 |
Thu, 08 November 2012 10:53 By: Mastah Naleh |
Deploy WAR to VTS Having trouble deploying a standard WAR on Virgo Tomcat Server By: m t on Fri, 29 June 2012 |
2 |
5651 |
Wed, 07 November 2012 15:29 By: Diego Marafetti |
how to prevent double loading of blueprint extender (one loaded in kernel and one in user) |
5 |
4678 |
Wed, 07 November 2012 09:48 By: Yousef Fadila |
Can I import and export services when I'm using Virgo Snaps? |
5 |
4413 |
Wed, 07 November 2012 08:47 By: Markus Schmailzl |
Remote debug of spring classes How to attach source code to spring jars in repository/ext ? |
5 |
5243 |
Mon, 05 November 2012 10:53 By: Glyn Normington |
Virgo 3.6.0.M03 |
9 |
5251 |
Sat, 03 November 2012 00:14 By: Mastah Naleh |
Strange ClassNotFoundException problem with ClassNotFound |
1 |
3015 |
Fri, 02 November 2012 11:34 By: Glyn Normington |
Datasource not found in par deployment Virgo doesn't find my datasource |
4 |
4167 |
Fri, 02 November 2012 11:31 By: Glyn Normington |
Package merge Problem Cannot install bundles for iText1.3.4 and iText 2.1.7 |
1 |
4867 |
Fri, 02 November 2012 11:17 By: Glyn Normington |
Spring 3.2 and OSGi Real concern or rant ? |
3 |
6873 |
Fri, 02 November 2012 11:08 By: Glyn Normington |
VIrgo 3.0.3 and DEBUG mode and Eclipse Helios |
1 |
3234 |
Fri, 02 November 2012 11:04 By: Glyn Normington |
Dependency graph tool? Need an overview of all (transitive) dependencies of my project |
3 |
2691 |
Fri, 02 November 2012 10:14 By: Glyn Normington |
Problem with deployment using plans |
3 |
2421 |
Fri, 02 November 2012 10:02 By: Glyn Normington |
Bundlor 1.1.2.RELEASE |
0 |
12511 |
Thu, 01 November 2012 14:55 By: Glyn Normington |
Nexus and or Jenkins on Virgo 3.5 Has anyone else had any success deploying nexus or jenkins on virgo 3.5 |
2 |
2998 |
Thu, 01 November 2012 14:53 By: Pete Carapetyan |
Present your use of Virgo at EclipseCon? |
0 |
12538 |
Wed, 31 October 2012 13:25 By: Glyn Normington |
Virgo Reference Anyone? Help to promote Virgo and get more traffic to your site |
1 |
2616 |
Tue, 30 October 2012 16:12 By: Glyn Normington |
Is Virgo used in production environments? Trying to get a feel of the maturity level |
12 |
8668 |
Tue, 30 October 2012 16:00 By: Glyn Normington |
JPA, separate bundles for model and services How to configure JPA for separate model and service |
3 |
2593 |
Tue, 30 October 2012 13:29 By: Erik Vande Velde |
dynamic jasper osgi bundle |
4 |
7243 |
Tue, 30 October 2012 12:43 By: Miguel Salinas Gancedo |
virgo distribution without user region and with repository |
3 |
2396 |
Tue, 30 October 2012 11:56 By: Borislav Kapukaranov |
Problems after upgrading to Spring 3.1.2 java.lang.ClassNotFoundException: org.springframework.web.SpringServletContainerInitializer |
1 |
3641 |
Tue, 30 October 2012 02:39 By: Borislav Kapukaranov |
can virgo runs as single region(without kernel/user isolation) mode? |
4 |
2193 |
Tue, 30 October 2012 02:01 By: Borislav Kapukaranov |
Completeness of scoped plans Bundle gets pulled in scoped and unscoped |
2 |
3565 |
Mon, 29 October 2012 21:13 By: Thorsten Schlathölter |
Hibernate SessionFactory as osgi:service I have some problems with it... |
3 |
5642 |
Sat, 27 October 2012 23:31 By: Mastah Naleh |
How can I use JPA 2.0 with hibernate under virgo Need JPA 2.0 - hibernate combination |
2 |
2886 |
Wed, 24 October 2012 15:30 By: Erik Vande Velde |
OSGi manifests for Spring 3.2 (Java 7 users please note) |
0 |
13130 |
Wed, 24 October 2012 06:37 By: Glyn Normington |
class not found, package only package exported, but class not found |
14 |
13944 |
Sun, 21 October 2012 10:14 By: KwanKin Yau |
Virgo as Windows Service |
1 |
3721 |
Wed, 17 October 2012 10:08 By: Chris Frost |
Noob Question Repo Admin Service |
9 |
5416 |
Fri, 12 October 2012 11:18 By: Seth Helstrip |
Can you describe how you are using Virgo? Help to promote Virgo and get more traffic to your site |
0 |
13191 |
Fri, 12 October 2012 09:37 By: Glyn Normington |
Bundlor: No value found for placeholder 'xy' |
3 |
3459 |
Fri, 12 October 2012 00:09 By: Glyn Normington |
Virgo Tomcat Server 3.5.0 repository host returns 404 Having problems configuring a VTS repository host |
9 |
5737 |
Thu, 11 October 2012 15:20 By: Glyn Normington |
Spring contexts and aspectj weaver |
1 |
4104 |
Thu, 11 October 2012 15:07 By: Glyn Normington |
Virgo JVM not started using -server parameter |
1 |
1907 |
Thu, 11 October 2012 14:48 By: Glyn Normington |
<tx:annotation-driven /> not recognized migration Standard WAR -> Shared Libraries WAR problem |
3 |
5407 |
Thu, 11 October 2012 14:38 By: Glyn Normington |
How to get config artefacts to be seen in Eclipse's Servers view |
5 |
4720 |
Thu, 11 October 2012 10:22 By: Barbara Rosi-Schwartz |
Virgo 3.6.0.M02 Released |
0 |
12878 |
Thu, 11 October 2012 08:36 By: Borislav Kapukaranov |
Application wide configuration |
4 |
2861 |
Wed, 10 October 2012 19:00 By: Tin N/A |
Timing on deploying a Plan |
4 |
4867 |
Tue, 09 October 2012 17:20 By: Justin Stewart |
Maven repository for Virgo artifacts? |
7 |
10918 |
Tue, 09 October 2012 11:17 By: Thorsten Schlathölter |
Statement of direction: OSGi Subsystems spec support |
5 |
5035 |
Mon, 08 October 2012 09:20 By: Glyn Normington |
Virgo + ConditionalPermissionAdmin question By: E S on Mon, 08 October 2012 |
2 |
2517 |
Mon, 08 October 2012 08:17 By: E S |
Spring Web Services & Virgo 3.0.x No Servlet3 - based Spring Web Services available in EBR |
2 |
4462 |
Tue, 02 October 2012 07:33 By: Glyn Normington |
Autowiring services >1 deep Having problems wiring a chain of services |
3 |
4569 |
Mon, 01 October 2012 07:54 By: Glyn Normington |
ClassNotFoundException: org.springframework.context.config.ContextNamespaceHandler WAB unable to locate spring context handlers |
4 |
19550 |
Sat, 29 September 2012 20:16 By: Benoit Lafleche |
Virgo 3.6.0.M01 Released |
1 |
2157 |
Fri, 28 September 2012 19:15 By: Mastah Naleh |
Deploying wab with persistence.xml Caused by: java.lang.IllegalArgumentException: No persistence unit with name 'hibernatePersistenceUnit' found |
1 |
12049 |
Fri, 28 September 2012 10:09 By: Glyn Normington |
Eclipse Virgo's auto deploy takes long time when many files Eclipse Virgo's auto deploy takes long time when many static resources |
1 |
5241 |
Fri, 28 September 2012 10:05 By: Glyn Normington |
change virgo to use aries instead of gemini |
1 |
2752 |
Fri, 28 September 2012 09:56 By: Glyn Normington |
Virgo Tools 3.5.0 Released |
6 |
4623 |
Fri, 28 September 2012 02:56 By: Bin Zhang |
NoClassDef: javax/management/ObjectName from Web Bundle NoClassDef: javax/management/ObjectName from Web Bundle |
1 |
2503 |
Thu, 27 September 2012 18:46 By: Tom Missing name |
How to use JNDI to lookup services How to use JNDI to lookup services |
2 |
2475 |
Wed, 26 September 2012 19:22 By: Violeta Georgieva |
working shared library war for VTS 3.5.0 I need a working example |
0 |
14188 |
Tue, 25 September 2012 07:46 By: Erik Vande Velde |
migration to 3.5.0 camel with blueprint issues |
0 |
15693 |
Thu, 20 September 2012 12:25 By: jacob hameiri |
VTS not finding resource file VTS not finding resource file |
2 |
4248 |
Thu, 20 September 2012 07:49 By: Erik Vande Velde |
hi,a error of SpringAMQP in Virgo spring amqp deployed in vrigo server |
2 |
3428 |
Thu, 20 September 2012 01:19 By: Amos Ping |
@Administrator/Moderator: Cleanup |
2 |
3413 |
Wed, 19 September 2012 15:24 By: Denis Roy |
Timeout when starting Blueprint Bundle in Virgo 3.5.0.RELEASE I created a working OSGi Bundle without a "/OSGI-INF/blueprint/blueprint.xml" and it starts, add the XML and it fails to start. |
1 |
3877 |
Wed, 19 September 2012 15:06 By: Glyn Normington |
Virgo in the cloud (AWS) - provisioning suggestions? Provisioning multiple EC2 Virgo instances from a shared repo |
1 |
2516 |
Wed, 19 September 2012 14:56 By: Glyn Normington |
Virgo Build - common directory for ivy repo |
4 |
6080 |
Mon, 17 September 2012 15:47 By: Chris Frost |
virgo 3.5 admin web use way virgo 3.5.0 org.eclipse.virgo.apps.admin.web_3.5.0 used ways |
1 |
2227 |
Mon, 17 September 2012 10:14 By: Chris Frost |
Spring 3.2 without OSGi meta-data? http://forum.springsource.org/showthread.php?129344-Spring-3-2-Milestone-1-and-OSGi-meta-data |
2 |
3359 |
Mon, 17 September 2012 09:03 By: Helmut Missing name |
Using same PersistenceUnit across bundles |
1 |
3135 |
Thu, 13 September 2012 18:48 By: Eduardo Frazão |
update to 3.5.0 failed |
5 |
4777 |
Thu, 13 September 2012 16:10 By: Miles Parker |
default web.xml in virgo 3.5.0 |
1 |
1846 |
Thu, 13 September 2012 14:12 By: Borislav Kapukaranov |
duplicated spring bundles |
2 |
2141 |
Wed, 12 September 2012 19:05 By: jacob hameiri |
Import packages in spring dependant bundle question |
1 |
3267 |
Wed, 12 September 2012 18:42 By: Chris Frost |
Virgo packaged Spring 3 bundles not having all dependencies fulfilled |
3 |
2313 |
Wed, 12 September 2012 18:28 By: Chris Frost |
How do you enable MemoryLeakProtection logging with Virgo Server for Apache Tomcat |
1 |
2700 |
Tue, 11 September 2012 18:20 By: Violeta Georgieva |
Security Manager AGAIN |
3 |
3393 |
Tue, 11 September 2012 08:45 By: eugene rabii |
Testing with Virgo Test Framework By: Wesley on Fri, 28 January 2011 |
5 |
6221 |
Fri, 07 September 2012 16:20 By: James Gartner |
Two RAP application in the SAME Virgo kernel Is this possible? |
9 |
10035 |
Thu, 06 September 2012 20:29 By: Charlie Mordant |
Virgo on cloudfoundry |
30 |
21030 |
Wed, 05 September 2012 12:00 By: Ruoyun Wu |
Cannot determine the artifact identity of the file spring dynamic module's bundles deployment on virgo server |
3 |
6102 |
Wed, 05 September 2012 10:51 By: Hristo Iliev |
ConditionalPermissionAdmin not working |
0 |
14341 |
Tue, 04 September 2012 12:57 By: eugene rabii |
0 |
14317 |
Security Manager + Virgo |
4 |
6918 |
Mon, 03 September 2012 10:09 By: eugene rabii |
plans how to use the tooling with plans instead of par |
2 |
2570 |
Mon, 03 September 2012 09:02 By: daniel marthaler |
Virgo Nano Web tooling support can't select nano web as rt server runtime |
3 |
2819 |
Sat, 01 September 2012 11:20 By: daniel marthaler |
How-to-achieve-url-maxtry-filter-in-virgo tomcat server |
3 |
3146 |
Thu, 30 August 2012 18:11 By: Tin N/A |
Splash screen for Virgo kernel? |
5 |
5202 |
Wed, 29 August 2012 13:59 By: Barbara Rosi-Schwartz |
NoClassDefFoundError problem |
1 |
3040 |
Mon, 27 August 2012 08:14 By: Florian Waibel |
Spring Security @PreAuthorize is not working |
0 |
16470 |
Thu, 23 August 2012 11:46 By: damoder reddy |
Spring Security @PreAuthorize is not working Spring Security @PreAuthorize is not working when we are refering a service |
0 |
18014 |
0 |
14401 |
Wed, 22 August 2012 15:39 By: Vladimir Stevanovic |
Re: Debugging boot delegation |
0 |
13336 |
Tue, 21 August 2012 19:08 By: Daniel McGreal |
5 |
4929 |
Roadmap for Virgo 3.6 ? |
4 |
2990 |
Tue, 21 August 2012 01:22 By: Borislav Kapukaranov |
Occasional start-up failure due to synchronisation in Virgo kernel |
5 |
6417 |
Fri, 17 August 2012 07:56 By: Glyn Normington |
cxf_dosgi running under virgo cxf-dosgi-ri-singlebundle-distribution-1.3.1.jar |
1 |
2478 |
Thu, 16 August 2012 08:46 By: Dennis Yang |
sample spring mvc app not working in virgo sample spring mvc app not working in virgo |
8 |
12988 |
Wed, 15 August 2012 21:52 By: Alex Antonov |
Virgo Snaps Sample 3.5 not complete |
5 |
4970 |
Mon, 13 August 2012 15:26 By: Glyn Normington |
VTS 3.0 - offline hosted repository How to configure the Virgo repository client to be able to startup with offline hosted repository |
1 |
3265 |
Mon, 13 August 2012 15:02 By: Glyn Normington |
Spring Security with multiple webapps |
1 |
3234 |
Mon, 13 August 2012 13:28 By: Glyn Normington |
Launching Virgo programmatically (say via Tanuki / java program) Launching Virgo programmatically (say via Tanuki / java program) |
3 |
4354 |
Sat, 11 August 2012 11:54 By: Hristo Iliev |
Exceptions injecting reserved beans in Blueprint |
1 |
3839 |
Wed, 08 August 2012 17:52 By: Anthony Bargnesi |
Hibernate Session Factory |
0 |
16117 |
Wed, 08 August 2012 15:09 By: Jens L. |
Configure Virgo to identify Web Context correct path Failure to resolve web context due to /localhost prefix |
2 |
3255 |
Tue, 07 August 2012 17:59 By: Chen Fliesher |
Clean doesn't work as expected running startup -clean still give the old index for new bundles |
3 |
3048 |
Tue, 07 August 2012 17:54 By: Chen Fliesher |
Bean factory post processors By: Tin N/A on Wed, 14 September 2011 |
14 |
12332 |
Tue, 07 August 2012 12:22 By: Tin N/A |
Virgo Server for Apache Tomcat - Production Usage |
6 |
6851 |
Fri, 03 August 2012 15:37 By: Tin N/A |
Missing artifact org.eclipse.virgo.mirrored:org.eclipse.osgi:jar:3.8.0.v20120508-2119 |
2 |
8879 |
Thu, 02 August 2012 00:35 By: Will Yao |
How to configure Embeded tomcat settings programatically in Virgo How to configure Embeded tomcat settings programatically in Virgo |
4 |
5797 |
Wed, 01 August 2012 15:22 By: anushka vaze |
Virgo and Mobicents, Integration issues Bundle errors when loading org.eclipse.virgo.web.tomcat_3.5.0.RELEASE.plan |
1 |
4814 |
Wed, 01 August 2012 10:55 By: Chen Fliesher |
Virgo Bundlor and Class Inheritance across Bundles |
2 |
3194 |
Fri, 27 July 2012 09:01 By: Glyn Normington |
Virgo and Gemini JPA plan failed |
2 |
2766 |
Fri, 27 July 2012 06:55 By: Charlie Mordant |
how to integrate spring security into virgo |
2 |
4915 |
Mon, 23 July 2012 13:48 By: Raju S |
Is it possible to extend log configuration without touching serviceability.xml? |
5 |
5991 |
Mon, 23 July 2012 08:45 By: Glyn Normington |
Will Snaps work with Apache Felix |
5 |
7348 |
Mon, 23 July 2012 08:41 By: Glyn Normington |
Hot deploy and bundle resolution |
2 |
3229 |
Fri, 20 July 2012 14:06 By: Nick Bargnesi |
Virgo Tooling M5 Release |
0 |
14159 |
Wed, 18 July 2012 23:08 By: Miles Parker |
"Virgo Nano Web" vs. "Virgo Server for Apache Tomcat" |
4 |
5309 |
Wed, 18 July 2012 06:39 By: Jean-Pierre Bergamin |
OSGI + Virgo + Snaps + JSF 2 Sample |
0 |
14677 |
Mon, 16 July 2012 19:26 By: dimitar nenchev |
Error deploying bundle with embedded jar to Virgo 3.5.0 |
2 |
6515 |
Mon, 16 July 2012 08:22 By: Glyn Normington |
Virgo 3.5.0.RELEASE |
2 |
21935 |
Sat, 14 July 2012 13:03 By: Glyn Normington |
Virgo 3.5.0.RC1 released |
3 |
6546 |
Fri, 13 July 2012 16:53 By: Scott Brand |
can bundlor fix up version numbers when generating the manifest? |
1 |
5463 |
Fri, 13 July 2012 08:49 By: Glyn Normington |
Issue with Non OSGi eclipse bundles |
1 |
5587 |
Fri, 13 July 2012 08:48 By: Glyn Normington |
Install Virgo using yum Is there any way to install Virgo Tomcat Server using yum |
1 |
19630 |
Thu, 12 July 2012 08:04 By: Daniel McGreal |
P2 update site for Virgo extensions P2 update site for Virgo extensions |
4 |
3090 |
Sun, 08 July 2012 13:47 By: Cameron Ross |
Virgo Tomcat Server for Apache Tomcat |
0 |
14894 |
Thu, 05 July 2012 09:06 By: Glyn Normington |
ActiveMQ Resolving error |
2 |
4590 |
Tue, 03 July 2012 12:59 By: Glyn Normington |
Virgo Bundlor released |
2 |
3908 |
Fri, 29 June 2012 14:30 By: Glyn Normington |
Virgo App Profiling/Performance Tuning |
1 |
3490 |
Fri, 29 June 2012 08:55 By: Hristo Iliev |
The osgi service injection and the order dynamic deploy on virgo inject osgi service dynamically and the order dynamic deploy on virgo |
2 |
4543 |
Thu, 28 June 2012 01:22 By: Percy Wang |
Can I use Virgo with my existing app and felix |
5 |
3140 |
Wed, 27 June 2012 17:09 By: Glyn Normington |
How do I include virgo/gemini support in my own tomcat Using my own tomcat, no virgo or gemini web embedded tomcat |
1 |
2061 |
Spring Security OAuth2 not loading Cannot resolve optional dependency to junit |
4 |
5395 |
Wed, 27 June 2012 16:38 By: Steve Suh |
installing spring-security-cas-client-3.0.5.RELEASE.jar |
0 |
14919 |
Wed, 27 June 2012 15:35 By: Marco Machmer |
JavaMail failes on virgo |
1 |
4633 |
Wed, 27 June 2012 11:29 By: Glyn Normington |
Where to upload text file in virgo server |
1 |
3103 |
Wed, 27 June 2012 09:53 By: Glyn Normington |
Running a boot-level bundle |
1 |
2264 |
Wed, 27 June 2012 09:42 By: Glyn Normington |
Getting started with Virgo (Virgin Project???) Trying to create new projects that can reference each other |
21 |
10367 |
Tue, 26 June 2012 22:42 By: Eduardo Frazão |
Error configuring application listener: ClassNotFoundException |
18 |
34134 |
Tue, 26 June 2012 19:22 By: Marcelo Riss |
How to import Bundle or Package in BundleManifestEditor |
5 |
6278 |
Mon, 25 June 2012 22:48 By: Leo Dos Santos |
Virgo Tomcat Server and Web Sockets |
2 |
2722 |
Fri, 22 June 2012 19:24 By: Matteo Cantarelli |
Upgrading Bundle |
3 |
3352 |
Mon, 18 June 2012 12:14 By: Glyn Normington |
P2 repository for Virgo Tomcat Server |
2 |
6120 |
Sun, 17 June 2012 12:22 By: Cameron Ross |
Installing spring security |
5 |
8636 |
Thu, 14 June 2012 13:33 By: Sebastián Seifert |
Thread Lock on Instantiate JFrame on Virgo Weird problem!! |
3 |
3541 |
Wed, 13 June 2012 23:52 By: Eduardo Frazão |
Virgo-maven-plugin with external local maven repository |
4 |
3247 |
Wed, 13 June 2012 23:00 By: Sebastián Seifert |
Starting Tomcat 7 as Embedded Server in OSGI Framework |
3 |
7021 |
Wed, 13 June 2012 16:45 By: Violeta Georgieva |
Redeployment int pickup directory does not work |
4 |
6858 |
Wed, 13 June 2012 09:13 By: Daniel Stieger |
Updating the springframework to version 3.11 RELEASE inside VTS want to figure out how to update the version of springframework inside VTS |
1 |
2640 |
Wed, 13 June 2012 08:56 By: Glyn Normington |
Bundlor 1.1.0.M05 |
1 |
2224 |
Wed, 13 June 2012 07:34 By: Glyn Normington |
Debugging Virgo in Spring Source Tool I would like to debug the bundles deployed in virgo using breakpoints that I have added in STS. |
1 |
3733 |
Wed, 13 June 2012 07:25 By: Glyn Normington |
Jetty WebSocket gets slow By: Tim D on Sat, 09 June 2012 |
1 |
4157 |
Wed, 13 June 2012 06:53 By: Hristo Iliev |
Greenpages H2 DB Locked Cannot create greenpages db |
1 |
4005 |
Tue, 12 June 2012 19:37 By: Jay Flowers |
Web bundle does not start when url-pattern=* |
6 |
5806 |
Tue, 12 June 2012 19:31 By: Violeta Georgieva |
OSGi case study |
0 |
14903 |
Tue, 12 June 2012 14:25 By: Glyn Normington |
Spring Configurable across multitple bundles |
2 |
5034 |
Thu, 07 June 2012 12:36 By: Frieder Heugel |
Virgo Tooling M4 Released |
4 |
24479 |
Mon, 04 June 2012 12:28 By: Benoit Lafleche |
Virgo Startup Problem |
3 |
3125 |
Fri, 01 June 2012 09:38 By: Glyn Normington |
javax.servlet.http.HttpServlet Caused by: java.lang.ClassNotFoundException: javax.servlet.http.HttpServlet |
7 |
14623 |
Thu, 31 May 2012 13:05 By: Kristina Taylor |
Some support |
0 |
15336 |
Thu, 31 May 2012 07:34 By: Daniel Stieger |
The watched repository does not automatically picks up artifacts |
2 |
2430 |
Wed, 30 May 2012 21:33 By: Rich Mayfield |
Embedded system startup time Optimizing the startup time on an embedded system |
5 |
4010 |
Wed, 30 May 2012 15:47 By: Rich Mayfield |
