Topic |
Replies |
Views |
Last message |
more 3.6 update issues |
0 |
29315 |
Wed, 15 January 2014 00:27 By: Jacob Hameiri |
3.0.1 to 3.6 migration issues |
4 |
9853 |
Tue, 14 January 2014 19:04 By: Jacob Hameiri |
Par/plan Scoping issue |
2 |
12457 |
Mon, 13 January 2014 14:09 By: Franck Mising name |
[SOLVED] AspectJ Weaver error on @Aspect Using AspectJ LTW in adiction with Spring AOP |
11 |
32800 |
Thu, 02 January 2014 10:41 By: Eduardo Frazão |
Virgo bundle hold on too much memory virgo BundleDescriptionImpl uses too much memory |
7 |
6016 |
Sun, 22 December 2013 17:36 By: chitong chung |
No Handler for type forms.widgets.ToggleHyperlink |
4 |
9957 |
Wed, 18 December 2013 11:15 By: Tilak Sharma |
Web app fails to start when including ContextLoaderListener in web.xml |
21 |
70744 |
Wed, 18 December 2013 09:57 By: Sana Aiman |
Vrigo tooling does not copy static resources to 'work' after change Vrigo tooling does not copy static resources to 'work' after change |
5 |
7297 |
Tue, 17 December 2013 20:33 By: jc perron |
virgo-kernel-3.6.2.RELEASE as windows service virgo-kernel-3.6.2.RELEASE as windows service |
0 |
15356 |
Fri, 13 December 2013 01:59 By: oumi casha |
Virgo Service commands are not working I am getting errors when I try to use the list or examine for vsh:service |
9 |
6459 |
Fri, 13 December 2013 01:51 By: oumi casha |
Virgo as windows service Changes between 3.2.0 and 3.5.0 for starting Virgo as windows service |
14 |
15131 |
Fri, 13 December 2013 01:49 By: oumi casha |
Equinox based War to Virgo plan Trying to migrate to VTS |
4 |
16726 |
Fri, 13 December 2013 01:29 By: oumi casha |
Enabling DEBUG logging in spring security classes Enabling DEBUG logging in spring security classes |
7 |
14529 |
Thu, 12 December 2013 15:50 By: Raghuram Devarakonda |
How to verify Application are Deployed I would like to know how to confirm resources and applications are correctly deployed. |
6 |
4404 |
Wed, 11 December 2013 14:39 By: Kevin Coy |
JAX-WS Web Service support |
5 |
14061 |
Wed, 11 December 2013 13:22 By: Laurent Gauthier |
Problem Running Greenpages under STS/Eclipse |
7 |
8047 |
Wed, 11 December 2013 09:32 By: Christian Bonami |
Disabling Security Manager in Virgo Disabling Security Manager in Virgo |
1 |
2323 |
Wed, 27 November 2013 08:55 By: Florian Waibel |
Update Server config (VM Arguments) I need to update one of the VM argument, but it doesn't success. |
3 |
3422 |
Wed, 27 November 2013 08:41 By: Glyn Normington |
Help about Install Virgo Snaps |
1 |
2251 |
Thu, 21 November 2013 10:02 By: Florian Waibel |
emf.ecore.resource.ResourceSet.getResource takes more time in VIRGO emf.ecore.resource.ResourceSet.getResource takes more time in VIRGO |
6 |
6742 |
Wed, 20 November 2013 12:35 By: Chandre Gowda |
Refreshed Virgo Buildpack |
0 |
7681 |
Fri, 15 November 2013 06:25 By: Glyn Normington |
Service configuration error loading a java service |
4 |
5774 |
Tue, 12 November 2013 03:14 By: Murthy Bhat |
KernelBundleClassLoader - Wiring problem? Spring-web classpath vs. my bundle classpath |
1 |
6251 |
Fri, 08 November 2013 19:33 By: Eduardo Frazão |
greenpages sample getting errors on junit test greenpages sample getting errors on junit test Caused by: org.springframework.beans.factory.BeanCreationException |
4 |
7682 |
Sat, 02 November 2013 15:50 By: Brent Jacox |
Java EE 6 Web Profile |
8 |
5772 |
Wed, 30 October 2013 18:44 By: Violeta Georgieva |
Running Virgo as a lightweight container with Docker |
0 |
4896 |
Wed, 30 October 2013 00:46 By: Florian Waibel |
Maven - compiling against Equinox in Virgo 3.6.2.RELEASE Using Maven as standalone (e.g. automated build) to build bundles for a Virgo target. |
6 |
7372 |
Tue, 29 October 2013 04:17 By: Douglas Beattie |
Spring MVC with blueprint |
1 |
12580 |
Sat, 26 October 2013 04:51 By: haijun sheng |
Deployment of Virgo runtime dependencies: Maven-based builds without Eclipse IDE Options for deploying dependencies; p2 repository, or other, with or without tycho. |
4 |
6464 |
Fri, 25 October 2013 17:15 By: Douglas Beattie |
javax.management error in virgo dependency from de.schlichtherle.truezip |
3 |
3647 |
Thu, 24 October 2013 07:53 By: Murthy Bhat |
Virgo OSGi with custom Vaadin component IncompatibleClassChangeError |
3 |
4313 |
Tue, 22 October 2013 18:58 By: Eduardo Frazão |
Example of a custom {ContextPath}.xml file |
4 |
3810 |
Mon, 21 October 2013 15:44 By: William Suetholz |
Bundles inside plans are started concurrently, causing problems |
4 |
5483 |
Fri, 11 October 2013 15:39 By: Glyn Normington |
Spring Context created in multiple threads? |
0 |
2933 |
Fri, 11 October 2013 13:22 By: Sven Panko |
InfoQ interview on Virgo |
1 |
2368 |
Mon, 07 October 2013 14:25 By: Eduardo Frazão |
Start VTS in Debian as process - define execution user possibility to configure process user in virgo |
1 |
11293 |
Fri, 04 October 2013 06:10 By: daniel marthaler |
using autbind on linux for virgo tomcat server to bind on ports < 1024 |
3 |
12092 |
Fri, 04 October 2013 06:01 By: daniel marthaler |
Virgo Project wil be archived? |
11 |
8050 |
Wed, 02 October 2013 14:35 By: Eduardo Frazão |
Is it possible to independently upgrade the version of Tomcat used by Virgo Tomcat? |
13 |
8563 |
Tue, 24 September 2013 11:31 By: Eduardo Frazão |
Using javamail for SMPTS on virgo fails on typo |
4 |
6091 |
Mon, 23 September 2013 21:05 By: Eduardo Frazão |
Virgo Project Leadership |
4 |
5339 |
Mon, 23 September 2013 20:55 By: Eduardo Frazão |
Bean Validation How can I use it with Gemini JPA |
0 |
2412 |
Mon, 23 September 2013 20:52 By: Eduardo Frazão |
hibernate.cfg issues Need to understand exact meaning of log message |
4 |
5060 |
Tue, 17 September 2013 06:38 By: Erik Vande Velde |
Creating logback logger, programatically. Class cast exception on LoggerContext, caused by multiple bundles exporting the same packages |
0 |
3633 |
Mon, 16 September 2013 16:18 By: Daniel McGreal |
Custom OSGi Container vs Virgo What are the advantages of Virgo over custom OSGi container |
5 |
7030 |
Mon, 16 September 2013 05:21 By: Tin N/A |
Spring Security Spring Security Implementation |
0 |
2596 |
Tue, 10 September 2013 12:04 By: Soham Ghosh |
Redeploying WAR in pickup reloads all WAR bundles |
1 |
1971 |
Tue, 10 September 2013 10:59 By: Dmitry Sklyut |
virgo 3.6.2 java.lang.NoClassDefFoundError: javax/servlet/Servlet can't find javax.servlet.Servlet in virgo 3.6.2 |
2 |
6697 |
Thu, 05 September 2013 02:08 By: qing paul |
can not deploy CXF 1.3.1 on Virgo 3.5 |
10 |
10136 |
Wed, 21 August 2013 03:51 By: dalei dai |
greenpages failing unit tests java.lang.NoClassDefFoundError: org/apache/commons/logging/LogFactory |
6 |
6450 |
Mon, 19 August 2013 13:07 By: Stijn Lambert |
Too low performance of legacy WAR-application |
2 |
4308 |
Tue, 30 July 2013 12:09 By: anshul awasthi |
schema resolution The osgi compendium schema is not found - am I missing a jar? |
0 |
1890 |
Wed, 24 July 2013 15:39 By: Douglas Jackson |
AspectJ LTW on Virgo 3.6.2 |
2 |
3280 |
Wed, 17 July 2013 19:41 By: Florian Waibel |
Installing bundle via plan fails |
0 |
2543 |
Mon, 15 July 2013 08:12 By: Martin Baumgartner |
Uses violtion with cxf-dosgi 1.4 in virgo 3.6 Uses violtion with cxf-dosgi 1.4 in virgo 3.6 |
1 |
4615 |
Mon, 08 July 2013 16:33 By: Mdu Mising name |
Admin Virgo Console Missing Browse/Update on Artifacts panel |
3 |
2662 |
Mon, 08 July 2013 14:56 By: Chris Frost |
HTTP Service - Missing JARs? |
1 |
2671 |
Mon, 08 July 2013 13:39 By: Florian Waibel |
Does Virgo Jetty have support for the Jetty Maven plugin? woud be awesome for rapid app development |
1 |
1721 |
Mon, 08 July 2013 13:31 By: Florian Waibel |
Update bundles mentioned in plan file |
2 |
2530 |
Wed, 26 June 2013 20:56 By: venki j |
Virgo 3.6.2 Release |
3 |
24400 |
Wed, 26 June 2013 08:55 By: Bin Zhang |
VTS with context.xml valve class not found exception tomcat picketlink integration required valve configuration |
2 |
6398 |
Mon, 24 June 2013 10:21 By: vinayak bhadage |
Life after greenpages sample What are the next steps to create a modular web app |
4 |
3597 |
Wed, 19 June 2013 18:28 By: Mark Peters |
What is the correct location for defining "filterChainProxy"? |
2 |
3084 |
Wed, 19 June 2013 18:18 By: Raghuram Devarakonda |
Missing part in understanding OSGI Designing a rest api |
6 |
5497 |
Wed, 19 June 2013 09:06 By: Franz Martin |
Using bundles with Wars Virgo Web Apps |
2 |
12181 |
Tue, 18 June 2013 04:34 By: Violeta Georgieva |
Virgo as a daemon |
4 |
5472 |
Mon, 17 June 2013 14:05 By: Brian Williamson |
war deployment - "check the logs for more details" - where? |
1 |
9923 |
Thu, 13 June 2013 10:18 By: Violeta Georgieva |
Locked bundle on Windows prevents from Virgo IDE to resolve artefact |
2 |
6609 |
Tue, 11 June 2013 11:34 By: C TRAN-XUAN |
Transaction management in Virgo Which design is considered "best practice"? |
6 |
13564 |
Mon, 10 June 2013 20:27 By: Lars Behnke |
Spring annotation config |
4 |
12669 |
Sun, 09 June 2013 20:04 By: Rigas Grigoropoulos |
Help needed with basic resolution issue |
2 |
3806 |
Fri, 07 June 2013 16:20 By: Miles Parker |
OsgiBundleApplicationContextListener not listening to events from all bundles OsgiBundleApplicationContextListener received OsgiBundleApplicationContextRefreshedEvent from only couple of bundle out of 10 bundles |
0 |
33777 |
Fri, 07 June 2013 05:11 By: Manish Agarwal |
Web bundles are not working in PARs and Plans (Jetty) 404 error |
0 |
31736 |
Thu, 06 June 2013 05:19 By: Dmitry Naghin |
Virgo doesn't comeup restart of machine |
0 |
37305 |
Wed, 05 June 2013 09:13 By: Abhinav Mishra |
Virgo Bundlor + Maven |
2 |
5597 |
Tue, 04 June 2013 17:57 By: Sandile Keswa |
Reading XML file from external location Is there any way to add external directory to the bundle classpath? |
3 |
8222 |
Tue, 04 June 2013 14:13 By: Manish Agarwal |
WAB in plan not deployed |
0 |
46449 |
Tue, 04 June 2013 12:08 By: Mihael Schmidt |
Use tc Server in Virgo? servlet containers |
1 |
28567 |
Tue, 04 June 2013 11:20 By: Violeta Georgieva |
userregionfactory failed to start (only after reboot). By: malik on Mon, 12 December 2011 |
3 |
5508 |
Mon, 03 June 2013 17:46 By: shakthi k |
How to know when virgo finished loading all plugins |
4 |
4404 |
Thu, 30 May 2013 20:37 By: Sandile Keswa |
Virgo does not start up on Windows 2008 64 bit Virtual machine- Timeout exception thrown Virgo does not start up - seeing a timeout exception in the logs |
0 |
30013 |
Fri, 24 May 2013 19:20 By: shakthi k |
SpringIntegration 2.2.3.RELEASE + Maven + Virgo migrating from SpringIntegration 2.2.3.RELEASE application to Virgo |
0 |
25356 |
Thu, 23 May 2013 12:59 By: Paolo Pino |
Virgo dumps - 64bit vs 32bit OS? Virgo starts 100% of the time on 64bit OS and 50% of the time on 32bit OS. |
7 |
8094 |
Tue, 21 May 2013 21:28 By: Justin Griffin |
Bundle scopes and Config Admin service |
2 |
2934 |
Thu, 16 May 2013 18:20 By: t murray |
virgo server cannot start virgo,bundle,hibernate 4.1.0 |
1 |
10736 |
Wed, 15 May 2013 13:30 By: clayon zeng |
java.lang.NoClassDefFoundError: org/codehaus/jackson/map/ObjectMapper |
4 |
39551 |
Wed, 15 May 2013 08:38 By: Glyn Normington |
How to tell virgo to deploy my configurations first with eclipse tooling? How to tell virgo to deploy my configurations first with eclipse tooling? |
3 |
10235 |
Spring Web (3.2.2) + Jackson (1.9) |
3 |
6870 |
Tue, 14 May 2013 20:01 By: Pedro Mendoza |
bundle in ext directory cannot be resolved virgo,bundle |
0 |
22320 |
Tue, 14 May 2013 13:47 By: clayon zeng |
Random Problem While Booting Virgo Uses violation problem with uses conflict for import that occurs randomly when booting the Virgo server. |
1 |
4531 |
Mon, 13 May 2013 11:11 By: Glyn Normington |
Redeploy / ClassLoader problem |
1 |
12032 |
Mon, 13 May 2013 10:56 By: Glyn Normington |
Creating test - doesn't reach to the point where tests are executed Creating test - doesn't reach to the point where tests are executed |
0 |
23085 |
Mon, 13 May 2013 09:15 By: Unic Man |
Making bundles in Nexus available to virgo instance |
0 |
21034 |
Fri, 10 May 2013 13:31 By: Maarten Winkels |
Virgo with CXF Web Services |
7 |
10434 |
Thu, 09 May 2013 16:10 By: Paul DiMilla |
Problem deploying Apache CXF Webservice on Virgo: Cannot resolve XML Schema |
4 |
13115 |
Wed, 08 May 2013 15:12 By: Neil Corbet |
Virgo 3.6.1 and SpringFramework 3.2.2 Using SpringFramework 3.2.2 |
4 |
4501 |
Tue, 07 May 2013 15:44 By: Glyn Normington |
EMF and Virgo Problem while using EMF in Virgo |
1 |
13444 |
Mon, 06 May 2013 14:45 By: GianMaria Romanato |
Fragment fails to resolve if listed after host - Virgo Tools on Linux |
1 |
3082 |
Mon, 06 May 2013 13:36 By: GianMaria Romanato |
CDI support is virgo for server for Tomcat |
0 |
9726 |
Fri, 03 May 2013 10:07 By: Franck Mising name |
Virgo source bundles |
1 |
1593 |
Wed, 24 April 2013 00:15 By: Franck Mising name |
Virgo Integration Test - Step by Step Guide |
3 |
5852 |
Mon, 22 April 2013 07:40 By: Glyn Normington |
Using the Config admin service |
3 |
4962 |
Fri, 19 April 2013 14:34 By: Franck Mising name |
Eclipse plug-ins and extension points |
3 |
3383 |
Fri, 19 April 2013 11:27 By: Franck Mising name |
Race condition at virgo start |
8 |
6271 |
Thu, 18 April 2013 14:23 By: Christoph S. |
org.eclipse.virgo.web.dm from p2? |
2 |
3328 |
Wed, 17 April 2013 19:08 By: Borislav Kapukaranov |
Virgo 3.7.0.M01 |
0 |
3112 |
Wed, 17 April 2013 10:53 By: Glyn Normington |
New maven plugin for plans generator |
0 |
3621 |
Tue, 16 April 2013 09:07 By: Eduardo Fernández |
Global ServletFilter |
11 |
6949 |
Mon, 15 April 2013 08:46 By: Samir Bayani |
Virgo eclise tool : Error when change output folder java.lang.UnsupportedOperationException: Cannot open an input stream for |
0 |
2775 |
Thu, 11 April 2013 13:52 By: etherny etherny |
War not "Spring Powered" despite using lots of spring |
4 |
4499 |
Tue, 09 April 2013 15:51 By: Glyn Normington |
Virgo environment from inside the container |
1 |
4116 |
Tue, 09 April 2013 15:48 By: Glyn Normington |
Karaf feature to pom and plans transformer |
1 |
4346 |
Tue, 09 April 2013 15:44 By: Glyn Normington |
Import-Bundle resolution not able to import packages |
1 |
4256 |
Tue, 09 April 2013 15:40 By: Glyn Normington |
Virgo + RAP + OSGi: Extension Points and Fancy Theme |
3 |
5534 |
Tue, 09 April 2013 10:33 By: Florian Waibel |
Remote command execution to the SSH shell? |
4 |
6513 |
Sun, 07 April 2013 16:35 By: Lazar Kirchev |
NoClassDefFoundError on SpringBlueprintContainer when installing cxf-api |
9 |
12348 |
Fri, 05 April 2013 09:10 By: C TRAN-XUAN |
virgo in the cloud |
0 |
3589 |
Thu, 04 April 2013 14:25 By: Glyn Normington |
Declarative Transaction Demarcation using AOP pointcuts |
0 |
4917 |
Thu, 04 April 2013 13:32 By: Sebastian Lorenz |
Weekly calls? |
152 |
2907 |
Wed, 03 April 2013 15:10 By: Glyn Normington |
Virgo 3.6.1 admin console/ssh issues |
118 |
6788 |
Mon, 01 April 2013 22:15 By: James Gartner |
No frame contents in Swing app on Virgo |
24 |
10078 |
Thu, 28 March 2013 09:47 By: Miroslav Lansky |
Remote Node Management |
4 |
3380 |
Mon, 25 March 2013 12:40 By: Gunnar Wagenknecht |
Spring data |
4 |
4665 |
Sun, 24 March 2013 17:28 By: Daniel McGreal |
NoClassDefFoundError for javax.annotation.Priority |
2 |
12337 |
Sun, 24 March 2013 16:42 By: Eduardo Fernández |
LDAP over SSL keystore |
5 |
6431 |
Wed, 20 March 2013 15:10 By: Simon Zhu |
exporting services via spring configuration not working |
10 |
5898 |
Wed, 20 March 2013 14:27 By: James Gartner |
Deploying Multiple Bundles at Once |
3 |
2589 |
Tue, 19 March 2013 14:25 By: Glyn Normington |
Problem deploying CXF JAX-RS services in Virgo |
0 |
5976 |
Sun, 17 March 2013 18:48 By: Eduardo Fernández |
Requiring org.slf4j.api causes uses violations in empty server |
5 |
10492 |
Mon, 11 March 2013 16:54 By: Glyn Normington |
Not able to load Run Time JRE class: com.sun.crypto.provider.SunJCE Caused by: java.lang.ClassNotFoundException: com.sun.crypto.provider.SunJCE |
3 |
6217 |
Mon, 11 March 2013 09:43 By: Glyn Normington |
Virgo Crashing on Resolution Failure |
4 |
3284 |
Mon, 11 March 2013 09:38 By: Glyn Normington |
My virgo start meet error:"Configuration failed with the following problems" start error |
1 |
4289 |
Fri, 08 March 2013 09:47 By: Glyn Normington |
Netbeans plugin for Virgo Tomcat Server |
1 |
2898 |
Fri, 08 March 2013 09:30 By: Glyn Normington |
Debugging class loading issues |
3 |
7695 |
Wed, 06 March 2013 11:37 By: Glyn Normington |
LogService per Bundle |
1 |
4058 |
Wed, 06 March 2013 11:32 By: Glyn Normington |
ExtendedClassNotFoundException with spring security 3.2 and spring 3.2 |
5 |
8267 |
Wed, 06 March 2013 10:21 By: Glyn Normington |
TransactionManager in Virgo 3.6.0? |
4 |
9372 |
Tue, 05 March 2013 16:08 By: Jean-Pierre Bergamin |
EclipseCon BOF |
0 |
5235 |
Mon, 04 March 2013 09:57 By: Glyn Normington |
Eclipse Virgo 3.0.2 Memory Eclipse Virgo is 32 or 64? |
1 |
2485 |
Fri, 01 March 2013 12:04 By: Jacek Kozieł |
Virgo 3.6.1 Release |
0 |
5070 |
Thu, 28 February 2013 13:20 By: Violeta Georgieva |
Cannot install GreenPages app on Virgo 3.6.0.release Unable to satisfy dependencies of bundle 'greenpages-2.5.0.RELEASE-green pages.web' at version '2.5.0': A library with the name 'org.springframework.spring' and a version within the range '[3.0.0, 3.1 |
4 |
6390 |
Wed, 27 February 2013 14:51 By: Chris Frost |
Virgo IDE 1.0.1.RELEASE |
0 |
4834 |
Wed, 27 February 2013 02:04 By: Leo Dos Santos |
Some open sourced Virgo plans I just uploaded some virgo plans on Github |
5 |
4677 |
Tue, 26 February 2013 11:52 By: Charlie Mordant |
Starting with a Custom Configuration 7.5 Starting with a Custom Configuration Directory still pointing to 8080 port |
7 |
6608 |
Tue, 26 February 2013 09:14 By: Anjan Kumar |
FuseBundles support? |
0 |
4854 |
Fri, 22 February 2013 20:02 By: Jean-Pierre Bergamin |
What is the difference between bundle fragment and snap? |
1 |
2979 |
Wed, 20 February 2013 11:29 By: Chris Frost |
Virgo Survey (2013) Results |
0 |
5241 |
Mon, 18 February 2013 16:19 By: Glyn Normington |
Deployment in Eclipse results in empty MANIFEST.MF |
1 |
2808 |
Sat, 16 February 2013 00:23 By: Leo Dos Santos |
Static EclipseLink weaving causing endless bundle refresh |
5 |
4164 |
Sat, 16 February 2013 00:00 By: Simon Watson |
Guide to getting Greenpages working under Eclipse |
0 |
6498 |
Fri, 15 February 2013 10:54 By: Glyn Normington |
Hosted repository with virgo tomcat server 3.0.2 |
13 |
8675 |
Fri, 15 February 2013 09:09 By: daniel marthaler |
How to use spring-aspects-3.2.1.RELEASE with aspectj-1.7.1? |
1 |
3002 |
Thu, 14 February 2013 15:41 By: Jean-Pierre Bergamin |
Virgo Server Adapter Immediate Shutdown |
2 |
13104 |
Thu, 14 February 2013 10:19 By: Glyn Normington |
Greenpages Maven Build Failure Maven Package Build Failure in Greenpages 2.3.0 and 2.4.0 |
2 |
3167 |
Thu, 14 February 2013 09:17 By: Cene Lavrič |
Greenpages app not working from eclipse app works with manual deploy, not from eclipse |
9 |
6325 |
Thu, 14 February 2013 09:09 By: Cene Lavrič |
Greenpages pom.xml Problem |
2 |
5449 |
Thu, 14 February 2013 08:56 By: Cene Lavrič |
Hibernate and OSGi |
0 |
6886 |
Wed, 13 February 2013 14:37 By: Glyn Normington |
Installation of plan 'org.eclipse.virgo.web.tomcat' failed: FatalIOException: Cannot move path |
1 |
4886 |
Tue, 12 February 2013 16:25 By: Glyn Normington |
Using plans with Virgo tooling How can I use a Virgo plan within my development environment (Eclipse IDE)? |
2 |
5348 |
Fri, 08 February 2013 20:02 By: Leo Dos Santos |
Inconvenient wiring diagrams in the admin console. |
1 |
4184 |
Fri, 08 February 2013 14:29 By: Glyn Normington |
Investigating OSGi and Virgo Call for help and documentation |
5 |
5881 |
Fri, 08 February 2013 11:01 By: Glyn Normington |
How to get EclipseRT/Virgo option in preferences>server>runtime environments? |
1 |
2942 |
Thu, 07 February 2013 13:51 By: Martin Lippert |
The "Require-Bundle" trick don't work with c3p0 pool |
1 |
2369 |
Thu, 07 February 2013 02:27 By: Dmitry Sklyut |
Running a wab on virgo nano + gemini web |
2 |
3219 |
Wed, 06 February 2013 05:34 By: Tobias Hammerschmidt |
lib/endorsed not honoured by Eclipse Bundle Dependencies classpath container |
1 |
2854 |
Wed, 06 February 2013 02:05 By: Leo Dos Santos |
Is it normal to get a dump for invalid char in manifest.mf? |
2 |
1758 |
Tue, 05 February 2013 22:22 By: Laurent Delamare |
How do you set up Spring AOP/AspectJ/Virgo |
16 |
23708 |
Tue, 05 February 2013 15:14 By: Eduardo Frazão |
Configurations and service.factoryPid How to associate multiple Configurations to one ManagedServiceFactory PID? |
7 |
7134 |
Tue, 05 February 2013 12:47 By: Dmitry Sklyut |
Initial artifact vs plan deployed in pickup |
4 |
5545 |
Mon, 04 February 2013 13:48 By: Glyn Normington |
Optional import of a hibernate's package unexpectedly became unresolved |
8 |
27080 |
Sun, 03 February 2013 19:52 By: Anton Lem |
Configuration bundles for managed service factory |
3 |
4450 |
Fri, 01 February 2013 16:16 By: Dmitry Sklyut |
Virgo ability to work with unpacked bundles |
5 |
4015 |
Thu, 31 January 2013 10:38 By: Glyn Normington |
Virgo Survey closing on 14 February |
0 |
8385 |
Wed, 30 January 2013 10:27 By: Glyn Normington |
Should Spring 3.0.7 be supported by Virgo 3.6? |
1 |
3058 |
Tue, 29 January 2013 12:06 By: Glyn Normington |
Eclipse like extension points in WebApp Eclipse like extension points in WebApp |
4 |
3921 |
Mon, 28 January 2013 16:29 By: GianMaria Romanato |
Per-application log doesn't capture bundle startup message |
3 |
4026 |
Mon, 28 January 2013 10:15 By: Glyn Normington |
Installation and Using of Virgo Maven Plugin Installation and Using of Virgo Maven Plugin |
2 |
6302 |
Thu, 24 January 2013 19:30 By: Albert Attard |
Doubts regarding ManagedServiceFactory |
1 |
1850 |
Wed, 23 January 2013 15:27 By: Castor Rodriguez |
Problem with Gemini DBAccess / JPA and Virgo 3.6 My plan constantly starts/stops when trying to deploy a persistence unit bundle |
3 |
4226 |
Fri, 18 January 2013 10:58 By: Simon Watson |
Virgo Community Survey including fun quiz |
2 |
2336 |
Thu, 17 January 2013 14:49 By: Glyn Normington |
IllegalArgumentException: MALFORMED while processing my servlet XML |
1 |
3085 |
Tue, 15 January 2013 09:18 By: Daniel McGreal |
ClassNotFoundException: javax.validation.spi.ValidationProvider after upgrade to Virgo 3.6 |
11 |
19249 |
Tue, 15 January 2013 09:16 By: Glyn Normington |
ActiveMQ Integration How to drop in ActiveMQ broker |
3 |
7670 |
Mon, 14 January 2013 11:54 By: Glyn Normington |
Virgo automatically stops |
6 |
4824 |
Mon, 14 January 2013 10:42 By: Miguel Salinas Gancedo |
"bundleContext property is required"? Exception trying to get simple (non-web) bundle working under Virgo 3.6 |
3 |
5286 |
Mon, 14 January 2013 08:56 By: Chris Frost |
war to wab why some classes are not awailable? |
4 |
6251 |
Mon, 14 January 2013 07:24 By: Violeta Georgieva |
Tomcat 7.0.32 springsource availability |
1 |
2344 |
Fri, 11 January 2013 06:24 By: Violeta Georgieva |
Bundle manifest problem since 3.6 Can't export / import package on some bundles |
1 |
5054 |
Thu, 10 January 2013 23:05 By: Chris Frost |
Virgo Snaps question virgo |
5 |
3754 |
Thu, 10 January 2013 18:13 By: Chris Frost |
SynchronousBundleListener |
2 |
1875 |
Mon, 07 January 2013 16:31 By: Glyn Normington |
New Import-Package not resolved on hot-deploy |
1 |
2003 |
Mon, 07 January 2013 16:08 By: Glyn Normington |
no security manager: RMI class loader disabled RMI - OSGi problems |
6 |
8744 |
Fri, 04 January 2013 15:17 By: Erik Vande Velde |
Why we stopped using Virgo/OSGi in our project The End (?) |
1 |
3132 |
Fri, 04 January 2013 10:29 By: Glyn Normington |
Transaction Management with Virgo Managing transactions from other osgi bundles |
2 |
4216 |
Fri, 04 January 2013 09:59 By: Erik Vande Velde |
Problem installing hibernate library bundles |
1 |
4805 |
Wed, 02 January 2013 14:54 By: Glyn Normington |
Bundlor issue with blueprint |
1 |
5108 |
Wed, 02 January 2013 14:38 By: Glyn Normington |
Virgo 3.6.0 Released |
2 |
4782 |
Wed, 02 January 2013 09:02 By: Glyn Normington |
Deployment of WAR in Virgo Class loading issues while deploying WAR file in VIRGO |
2 |
3739 |
Tue, 25 December 2012 18:01 By: Violeta Georgieva |
jdbc code in mysql how to add jdbc drivers with mysql db on hibernate app in eclips |
0 |
9412 |
Mon, 24 December 2012 14:04 By: izaz ahmed |
Eclipse Virgo shutsdown for no reason after some hours on EC2 |
14 |
12001 |
Sun, 23 December 2012 12:28 By: Hristo Iliev |
