Topic |
Replies |
Views |
Last message |
postgrest using postgrest (rest) and dirigle + login By: steve t on Tue, 05 January 2021 |
1 |
2897 |
Tue, 05 January 2021 20:43 By: Yordan Pavlov |
Mobile Application support Discussions on the approach to Mobile Applications By: Eclipse User on Sat, 07 November 2015 |
4 |
7291 |
Mon, 23 April 2018 20:40 By: Jupp Schmitz |
Kafka as a Messaging Hub Kafka as a Messaging Hub By: Eclipse User on Sat, 06 May 2017 |
1 |
34138 |
Thu, 14 September 2017 09:20 By: johny kopparapu |
Node.js vs J2V8 Node.js vs J2V8 Discussion By: Eclipse User on Sat, 06 May 2017 |
3 |
41546 |
Sat, 27 May 2017 09:08 By: Eclipse User |
Plan Version 3 Major changes in version 3.x By: Eclipse User on Sat, 06 May 2017 |
28 |
22583 |
Wed, 17 May 2017 14:41 By: Eclipse User |
Vert.x for reactive apps Reactive Apps By: Eclipse User on Wed, 17 May 2017 |
0 |
15384 |
Wed, 17 May 2017 14:40 By: Eclipse User |
New Repository Structure Restructuring current Repository hierarchy |
4 |
6257 |
Mon, 15 May 2017 11:10 By: Eclipse User |
Remove Semantic Folders Remove First Level Semantic Folders By: Eclipse User on Sat, 06 May 2017 |
1 |
25288 |
Fri, 12 May 2017 17:15 By: Eclipse User |
Support for CommonJS |
1 |
29411 |
Thu, 11 May 2017 07:45 By: Eclipse User |
Integrated Client-side JS testing |
0 |
34488 |
Tue, 09 May 2017 13:58 By: Georgi Pavlov |
Release service |
0 |
34390 |
Tue, 09 May 2017 13:54 By: Georgi Pavlov |
Improved support for BDD and TDD for JS scripting services |
0 |
34813 |
Tue, 09 May 2017 13:43 By: Georgi Pavlov |
Cache and global context |
0 |
34793 |
Tue, 09 May 2017 13:34 By: Georgi Pavlov |
Support for the "realtime" usecases |
0 |
34838 |
Tue, 09 May 2017 13:25 By: Georgi Pavlov |
Adoption of NodeJS applications |
0 |
35287 |
Tue, 09 May 2017 13:07 By: Georgi Pavlov |
ES6 Runtime for Scripting Services |
0 |
35019 |
Tue, 09 May 2017 12:53 By: Georgi Pavlov |
Ops cockpit Support for the operator |
0 |
34897 |
Tue, 09 May 2017 12:47 By: Georgi Pavlov |
Support for more types of protection mechanisms per app multi factor authentications, certifactes, etc configurable per-app |
0 |
34858 |
Tue, 09 May 2017 12:36 By: Georgi Pavlov |
Supportability: Improved debugging of Scripting Services |
0 |
34915 |
Tue, 09 May 2017 12:25 By: Georgi Pavlov |
Improved Git support |
0 |
35038 |
Tue, 09 May 2017 12:07 By: Georgi Pavlov |
Improved extensions management |
0 |
35129 |
Tue, 09 May 2017 11:59 By: Georgi Pavlov |
Design time control of published runtime artifacts |
0 |
35476 |
Tue, 09 May 2017 11:09 By: Georgi Pavlov |
Production readiness Discussion for the required tools and processes that would nativly support production-ready releases in Dirigible |
0 |
35713 |
Tue, 09 May 2017 10:57 By: Georgi Pavlov |
More fresh, desktop-grade design-env UX |
0 |
36313 |
Tue, 09 May 2017 09:23 By: Georgi Pavlov |
PostgreSQL as a Default Database PostgreSQL as a Default Database By: Eclipse User on Sat, 06 May 2017 |
0 |
31035 |
Sat, 06 May 2017 15:11 By: Eclipse User |
Cassandra as a Repository Implementation Cassandra as a Repository Implementation By: Eclipse User on Sat, 06 May 2017 |
0 |
30768 |
Sat, 06 May 2017 15:02 By: Eclipse User |
Activiti as a Process Engine Include Activiti as a built-in process engine By: Eclipse User on Sat, 06 May 2017 |
0 |
31027 |
Sat, 06 May 2017 13:55 By: Eclipse User |
Dirigible Cloud Management Discussion about Dirigible Cloud Management user experience By: Eclipse User on Mon, 14 March 2016 |
9 |
11464 |
Sat, 06 May 2017 13:38 By: Eclipse User |
AppServer as non-OSGi Application Server Component to be based on non-OSGi framework By: Eclipse User on Sat, 06 May 2017 |
0 |
31020 |
Sat, 06 May 2017 13:32 By: Eclipse User |
Secured/Unsecured URLs Discussion Discussion about path changes after securing a url |
1 |
68020 |
Sat, 06 May 2017 13:17 By: Eclipse User |
Injected API Requests Requests for new Injected APIs By: Eclipse User on Tue, 25 August 2015 |
4 |
7702 |
Mon, 01 August 2016 12:44 By: Eclipse User |
JavaScript Engine Types Determination Discussion about JavaScript engine types and their support By: Eclipse User on Tue, 28 June 2016 |
1 |
3424 |
Tue, 28 June 2016 12:28 By: Yordan Pavlov |
Dirigible Testing Lab |
25 |
15816 |
Wed, 27 April 2016 06:43 By: Ekaterina Mitova |
Messaging Service API discussion Discussion about Messaging Service API By: Eclipse User on Fri, 21 August 2015 |
1 |
10960 |
Mon, 14 March 2016 07:49 By: Eclipse User |
Supportability: Remote debugging dirigible code |
2 |
4321 |
Mon, 14 December 2015 15:32 By: Georgi Pavlov |
Integration of 3d party libraries Possible options and use cases |
1 |
3913 |
Sat, 12 December 2015 11:12 By: Eclipse User |
NoSQL support with TinkerPop |
2 |
3924 |
Tue, 01 December 2015 10:26 By: Georgi Pavlov |
High-performance & scalable Runtime What would be the target architecture and components for a high-performance & scalable Runtime By: Eclipse User on Sat, 07 November 2015 |
1 |
5831 |
Fri, 13 November 2015 08:22 By: Eclipse User |
A/B Testing Discussion about A/B Testing requirements from application developers By: Eclipse User on Mon, 19 October 2015 |
1 |
7038 |
Fri, 23 October 2015 11:49 By: Pavel Genevski |
Dirigible CodeWeek Workshop - Feedback Dedicated topic for gathering feedback from participants of Dirigible CodeWeek Workshop (2015-10-17) By: Eclipse User on Mon, 19 October 2015 |
4 |
4816 |
Tue, 20 October 2015 12:10 By: Yordan Pavlov |
Performance issue with spring/eclipse classloader classes loaded by spring (java reflection) are not cached |
2 |
3435 |
Mon, 19 October 2015 07:22 By: Marouen Allala |
Dependency injection for Java scripting services |
0 |
4819 |
Fri, 18 September 2015 08:48 By: Pavel Genevski |
IoT Scenario Possible use cases and development scenarios for IoT projects with Dirigible |
0 |
4290 |
Sat, 12 September 2015 10:58 By: Yordan Pavlov |
Server vs. Server-less in RCP mode Pros and Cons about running a built-in server in RCP mode By: Eclipse User on Fri, 11 September 2015 |
0 |
6726 |
Fri, 11 September 2015 13:15 By: Eclipse User |
Welcome to eclipse.dirigible |
0 |
3389 |
Thu, 19 March 2015 14:55 By: Eclipse Webmaster |
FUDForum. Page generated in 0.03474 seconds
