Topic |
Replies |
Views |
Last message |
Relations not displayed in diagram |
4 |
4074 |
Wed, 16 November 2022 07:30 By: Pierre-Charles David |
[EMF Forms] EMF Combo Box in GenericEditor [EMF Forms] EMF Combo Box in GenericEditor |
1 |
2385 |
Thu, 08 September 2022 06:54 By: Pierre-Charles David |
UML Profile to Ecore |
2 |
3637 |
Tue, 30 August 2022 06:18 By: Pierre-Charles David |
Can I create DDL from an Ecore model I would like to create DDL from an Ecore model |
0 |
2663 |
Fri, 22 July 2022 15:31 By: John Ormerod |
Create ecore model from Sysml16 |
0 |
3684 |
Fri, 11 February 2022 15:43 By: Alberto Debiasi |
Serializing XMI file for ECORE models |
0 |
3422 |
Mon, 07 February 2022 13:50 By: Avi Shaked |
Serialize base class object |
0 |
2696 |
Mon, 18 October 2021 08:20 By: Gunnar Arndt |
Using EObject as Key in map structure EMF Ecore Models - EObject as Key in Hashmap |
0 |
2424 |
Fri, 24 September 2021 17:27 By: Thomas Stifter |
Errors When Adding Second Xcore project Code generation and duplicate type problems |
2 |
2605 |
Wed, 08 September 2021 17:49 By: Greg Lusk |
StateMachine Simulation on Sirius StateMachine Simulation on Sirius |
0 |
2164 |
Mon, 22 March 2021 06:48 By: Pei Yang |
EcoreTools setup file seems broken |
0 |
4704 |
Thu, 03 September 2020 14:39 By: Dimo Petroff |
Ecore differences in EA version 13 and 15 exports. Representing association navigability in Ecore |
1 |
1555 |
Wed, 19 August 2020 08:23 By: Pierre-Charles David |
Different validation results due to cardinality |
0 |
2128 |
Mon, 17 August 2020 15:14 By: Lars-Ola Osterlund |
an issue while creating an "Entities in a class diagram" using Ecore tools |
0 |
1845 |
Fri, 24 July 2020 21:50 By: nour nour |
classes missing when importing model package |
1 |
1605 |
Wed, 25 March 2020 10:59 By: Avi Shaked |
Linking values in compositions |
0 |
3897 |
Wed, 25 March 2020 09:00 By: Avi Shaked |
model instantiation with default model object type |
0 |
6669 |
Tue, 03 March 2020 09:05 By: Avi Shaked |
Does Ecore also feature, say, sequence and activity diagrams? |
1 |
6717 |
Tue, 03 March 2020 08:34 By: Avi Shaked |
How to find Papyrus update site for installing papyrus in obeo designer Finding papyrus update sites for obeo designer 11.3 |
1 |
1483 |
Tue, 14 January 2020 07:14 By: Pierre-Charles David |
Help with KerMeta Metamodel uml diagram |
2 |
1518 |
Wed, 11 December 2019 07:10 By: Pierre-Charles David |
0 |
4050 |
Tue, 10 December 2019 23:08 By: Dinara Sunrise |
Download site for latest build |
1 |
4591 |
Thu, 21 March 2019 07:32 By: Pierre-Charles David |
recusive subproperties |
0 |
7061 |
Tue, 05 February 2019 16:23 By: Bushra Harraq |
EPackage registration not deployed in any feature (and improvements) |
3 |
6038 |
Thu, 10 January 2019 09:12 By: Didier Vojtisek |
attribute cardinality if I have attribute at1: ecore:Ebyte[4]; is it correct? how it is encoded? what about having integer[4] or String[4]? |
0 |
3254 |
Wed, 12 December 2018 04:12 By: argaz amazig |
Default documentation of Ecore diagrams |
0 |
3564 |
Wed, 26 September 2018 14:01 By: pxDoc Team |
Operation '>' and '<' not recognized for type EDate I can compare date.... |
1 |
3814 |
Tue, 10 July 2018 08:40 By: Cedric Brun |
JUnit test cases for ecore models How to write own test cases for ecore models |
2 |
5501 |
Sun, 15 October 2017 11:26 By: Manoj Keshavaprakash |
Availability Viewpoint in Sirius How to get access to Sirius Viewpoint in the new Modelling Project? |
1 |
9628 |
Mon, 28 August 2017 15:38 By: Cedric Brun |
modeling |
3 |
5689 |
Thu, 12 January 2017 12:25 By: Banafsheh Azizi |
Sirius / Ecore Tools compatibility in Neon |
3 |
3788 |
Fri, 14 October 2016 15:34 By: Cedric Brun |
Load/Serialize JSON data into EMF Model EMF-JSON for loading and saving JSON data in EMF Model |
2 |
4137 |
Tue, 04 October 2016 19:21 By: Shwetha Venkatesh |
EAttribute "ID" with Auto Increment EAttribute "ID" with Auto Increment |
2 |
6580 |
Sat, 17 September 2016 08:43 By: Xi Ng |
Illegal argument exception for "Name" property |
1 |
2828 |
Tue, 06 September 2016 07:46 By: Cedric Brun |
Creating an "instance editor" ontop of ECore-model |
2 |
7601 |
Thu, 01 September 2016 12:41 By: Ralph Gerbig |
[Texo] Install texo in eclipse neon fails - org.json not found |
5 |
5402 |
Mon, 08 August 2016 09:02 By: Michael Wyraz |
Transforming Ecore diagrams with mediniQVT |
1 |
5287 |
Wed, 18 May 2016 08:53 By: Cedric Brun |
SPEM2 metamodel defined with Ecore SPEM2 metamodel defined with Ecore |
1 |
7184 |
Wed, 18 May 2016 08:18 By: Cedric Brun |
Convert Ecore models to UML programmatically |
1 |
5133 |
Wed, 18 May 2016 07:53 By: Cedric Brun |
Instantiation in emf |
1 |
6866 |
Wed, 18 May 2016 07:52 By: Cedric Brun |
EClass information view |
3 |
8556 |
Tue, 17 May 2016 15:08 By: Cedric Brun |
Convert Ecore to UML |
3 |
9748 |
Renaming and regeneration? |
2 |
7020 |
[Texo] Possibility to suppress generating of getter/setter |
1 |
6215 |
Wed, 20 January 2016 22:43 By: Martin Taal |
How to use compile-time annotations in ECore model without introducing runtime dependency |
2 |
5407 |
Mon, 21 December 2015 10:24 By: Andreas Sewe |
Opening .ecorediagram diagrams in Luna?? |
6 |
17026 |
Thu, 12 November 2015 12:54 By: Cedric Brun |
Accessing external meta-models and code generation |
1 |
5687 |
Wed, 19 August 2015 07:55 By: Thomas Lieser |
Error loading representations file in Mars (regression?) |
5 |
8144 |
Thu, 13 August 2015 16:16 By: Cedric Brun |
problem with the installation of ecore diagram editor |
1 |
7609 |
Wed, 05 August 2015 13:49 By: Cedric Brun |
How can I get changes on Ecore Model |
1 |
6546 |
Wed, 05 August 2015 13:46 By: Cedric Brun |
Ecore diagram editor does not load when I click the (aird) file |
1 |
5107 |
Wed, 15 July 2015 16:13 By: Cedric Brun |
How to serialize default values with domain specific editor |
1 |
4991 |
Wed, 15 July 2015 09:51 By: Cedric Brun |
Extending EcoreTools with new EAnnotation-based layers |
1 |
4453 |
Wed, 15 July 2015 09:47 By: Cedric Brun |
containment node problem By: 55 66 on Thu, 04 June 2015 |
1 |
4583 |
Wed, 15 July 2015 09:36 By: Cedric Brun |
IllegalArgumentException: Can only deactivate the active transaction Exception thrown when altering a model using Ecore Tools 2.0 |
1 |
4851 |
Sat, 11 April 2015 22:15 By: Sebastian Lehrig |
Adding custom EMF metamodel validation rules |
0 |
3768 |
Thu, 19 March 2015 17:44 By: Francois Cabrol |
Instantiation of an ecore model Cannot instantiate an own built ecore model |
0 |
3609 |
Sun, 08 February 2015 21:01 By: Beat Lussi |
Transforming Ecore-models via XSLT Is using XSLT to change references etc. a good idea? |
0 |
4295 |
Thu, 18 December 2014 12:17 By: Thomas Busch |
opposite reference in property view for bidirectional references |
0 |
5138 |
Sat, 29 November 2014 18:57 By: Sivka Burka |
Ecore tools 2.0.3 Issue with generic ETypeParameter In diagram editor cannot specify T extends SomeClass for type parameter T |
0 |
10966 |
Thu, 27 November 2014 00:11 By: Marcello Vitaletti |
Ecore Modeling Tools - missing create ecore Diagram By: Eclipse User on Tue, 11 November 2014 |
1 |
9510 |
Fri, 14 November 2014 14:01 By: Cedric Brun |
.genmodel file lost its editor association in RSA Can't reload .genmodel from .emx or see .ecore editor |
0 |
7433 |
Mon, 03 November 2014 02:11 By: Edmund Reinhardt |
syncing to xcore model syncing to xcore model |
0 |
5388 |
Sat, 25 October 2014 13:54 By: Neil Mackenzie |
Unexpected EOpposite validation error |
2 |
3858 |
Thu, 23 October 2014 15:47 By: Cedric Brun |
Sirius - viewpoint bug? problem on launching viewpoint specification project |
0 |
4372 |
Sun, 05 October 2014 22:27 By: andrea scarpa |
Eclipse Modelling Tools - Ecore Unable to access Ecore Diagram Editor |
2 |
4160 |
Thu, 18 September 2014 09:37 By: Cedric Brun |
Reference field UpperBound It is impossible to put a star in this field |
1 |
5102 |
Fri, 12 September 2014 10:11 By: Cedric Brun |
Ecore Tools 2 The XYZ class has more than 3 super types how to avoid this error: The XYZ class has more than 3 super types |
1 |
6648 |
Fri, 12 September 2014 10:06 By: Cedric Brun |
Ecore Tools 2.0 SuperType Relation name two SuperType Relation |
1 |
6453 |
Fri, 12 September 2014 10:01 By: Cedric Brun |
Ecore Tools 2.0 Project Creation Wizard - Sirius 1.0.1 problems Sirius 1.0.1 prevents new Ecore Tools 2 projects from creating class diagrams |
2 |
6060 |
Fri, 12 September 2014 09:59 By: Cedric Brun |
model ecore order of elements in model ecore |
1 |
4050 |
Fri, 12 September 2014 09:50 By: Cedric Brun |
ecore EMF and Model creation wizards the example in Example EMF Model creation wizards is apprearing but missing some information |
0 |
3895 |
Fri, 05 September 2014 13:49 By: walma gharbi |
Ecore Tools 2.0 bidirectional reference issue how to select only one reference to add annotations |
0 |
5763 |
Mon, 01 September 2014 04:38 By: joss Pf H |
Ecore Tools 2.0 how to select all classes into a package? how to select all classes into a package? |
0 |
3433 |
Thu, 21 August 2014 15:50 By: joss Pf H |
How to generate impl classes and edit, and editor projects How to generate impl classes and edit, and editor projects |
1 |
3723 |
Fri, 25 July 2014 10:03 By: Arunkumar Ramaswamy |
EType : java.util.Collection |
1 |
3233 |
Thu, 17 July 2014 06:50 By: Yugi Muto |
Ecore Tools 2.0 Outline "link with Editor" button Ecore Tools 2.0 Outline link with Editor |
4 |
6353 |
Sat, 12 July 2014 00:39 By: joss Pf H |
Ecore Tools 2 problems Ecore Tools 2 problems |
2 |
4775 |
Sat, 12 July 2014 00:21 By: joss Pf H |
Trouble installing/using Ecore Tools SDK |
5 |
12970 |
Mon, 07 July 2014 11:48 By: Cedric Brun |
Ecore Tools 2 Icon path problem Ecore Tools 2 Icon path problem |
2 |
4361 |
Fri, 27 June 2014 15:25 By: joss Pf H |
Error in xcore file in eclipse kepler Couldn't resolve reference to XAnnotationDirective 'GenModel' |
1 |
8385 |
Thu, 26 June 2014 10:33 By: Marco Descher |
Creating Diagrams for a subset of objects in the Ecore Model |
5 |
10115 |
Fri, 06 June 2014 12:23 By: Cedric Brun |
What means setGenerateCustomClasses in org.eclipse.emf.mwe2.ecore.EcoreGenerator |
0 |
57725 |
Wed, 28 May 2014 23:28 By: Markus Oley |
[SOLVED] Which package contains the presentation-relevant classes for the EMF Diagram editor? |
2 |
3627 |
Tue, 06 May 2014 12:21 By: Cedric Brun |
Load and use ECore resources with ECore Editor 2.0 |
2 |
12131 |
Mon, 28 April 2014 16:19 By: Aleksandar Toshovski |
Ecore Tools 2.0 support no generics in the new UML class diagram editor |
2 |
10939 |
Wed, 23 April 2014 08:43 By: Aleksandar Toshovski |
Latest builds are missing from the download site? |
2 |
6007 |
Thu, 17 April 2014 12:14 By: Cedric Brun |
Fragment and partially load EMF models in xmi format |
1 |
4413 |
Wed, 12 March 2014 17:07 By: Cedric Brun |
Resource creation ignores an attribute while saving to output file! |
0 |
2731 |
Tue, 25 February 2014 18:36 By: Parsa Pourali |
[teneo]recover bad connections [teneo]recover bad connections |
0 |
14272 |
Tue, 18 February 2014 19:47 By: Rachna Bakhru |
Tool for creating metamodel graphic By: Phil H on Sat, 01 February 2014 |
0 |
31521 |
Sat, 01 February 2014 21:04 By: Phil H |
Automatically generate EMF, Help! Automatically generate EMF, Help! |
1 |
8434 |
Thu, 30 January 2014 15:56 By: Salome Maro |
Populating a drop down list with existing classes Noob |
1 |
4719 |
Thu, 05 December 2013 10:39 By: Cedric Brun |
Metamodels in Ecore |
1 |
4496 |
Thu, 05 December 2013 10:38 By: Cedric Brun |
Autosave changed referenced objects possible? |
2 |
4995 |
Strange EOpposite references behaviour |
1 |
3662 |
Thu, 05 December 2013 10:37 By: Cedric Brun |
How to create one model from several XSDs? |
1 |
6565 |
Fri, 08 November 2013 11:01 By: Dominik foobar |
Correct way to override the accessors for an eAttribute |
0 |
3472 |
Mon, 07 October 2013 14:22 By: Corby James |
"Ecore Tools" called "Ecore Diagram Editor" since Eclipse Kepler / 4.3? |
2 |
8707 |
Wed, 14 August 2013 10:43 By: Mikhail Kalkov |
Getting an exception while loading a model |
0 |
3664 |
Fri, 02 August 2013 19:16 By: eshal shah |
Ecore Model Does Does Not Create Following Tutorial and get error in Indigo and Juno |
1 |
4605 |
Tue, 09 July 2013 10:22 By: Elvio Perino |
Texo: list of annoying details |
1 |
7360 |
Sun, 02 June 2013 08:20 By: Martin Taal |
[TEXO] getting started with texo.web.example exception when starting tomcat |
2 |
12543 |
Thu, 23 May 2013 09:41 By: Martin Taal |
[TEXO] texo skips to generate EOperations from ecore |
2 |
5540 |
Wed, 15 May 2013 13:01 By: Martin Taal |
Diff 2 EObjects of the same ecore model Diff 2 EObjects of the same ecore model |
0 |
4455 |
Tue, 07 May 2013 14:23 By: Andrew Whelan |
[TEXO] move from normal EMF to TEXO |
2 |
7216 |
Mon, 15 April 2013 05:05 By: Ludwig Moser |
Ecore parser ? I'm looking for a way to easily parse an ecore file. |
0 |
4080 |
Tue, 26 March 2013 15:24 By: loic Gammaitoni |
Test case generation from Ecore model Automated Test case generation from Ecore model for model based testing |
1 |
6420 |
Fri, 08 March 2013 14:23 By: Marina Knieling |
Ecore Tools on Kepler M5a |
1 |
3786 |
Mon, 25 February 2013 20:41 By: Pierre Gaufillet |
Ecorediag: how to add classes (or packages) from the ecore model |
0 |
5046 |
Thu, 21 February 2013 11:15 By: Davide M |
Is EMF Index a dead project? |
0 |
4137 |
Wed, 06 February 2013 19:28 By: Eric Rizzo |
Binding two EMF objcets How to bind two EMF domain objects |
0 |
3680 |
Wed, 06 February 2013 03:25 By: Ramesh Nachimuthu |
Documentation for EMF Query Required Documentation for EMF Query Required |
0 |
4313 |
Tue, 05 February 2013 13:37 By: Farsheed Farian |
Reading elements of a ecore file |
0 |
13611 |
Wed, 09 January 2013 11:46 By: Philipp El |
How to get files from Preject Explorer and Pakage Explorer to new View on Eclipse? |
0 |
5030 |
Mon, 17 December 2012 12:10 By: Saif Mfarrij |
ecore diagram: IllegalArgumentException on loadup |
0 |
4965 |
Wed, 12 December 2012 17:15 By: Simon Schimansky |
Initialize ECore diagram file only goes down one level How can I get the "Initialize ECore diagram file" to travel farther then one level? |
0 |
5522 |
Sat, 24 November 2012 22:25 By: Paul Roubekas |
Missing EMF Ecore diagram editor + Indigo JEE package 32 bit |
0 |
7658 |
Thu, 22 November 2012 07:00 By: Pradeep Badiger |
Resolve Ecore Cross Reference |
0 |
4692 |
Thu, 18 October 2012 16:04 By: Florian B. |
Ecore editor doesn't find a file |
0 |
6060 |
Tue, 02 October 2012 08:21 By: Alexey Romanov |
Persisting ecore model in DB takes too long time!!! |
0 |
6267 |
Fri, 14 September 2012 11:41 By: Harshagiri Kondavagilu |
Validation errors in Ecore metamodel |
1 |
23380 |
Thu, 12 July 2012 09:47 By: Sandra B |
JAXB annotation in Ecore |
0 |
5988 |
Mon, 09 July 2012 09:05 By: Kosala Yapa |
problem when trying to open my ecore with oclin ecore editor |
2 |
4645 |
Mon, 02 July 2012 12:44 By: frank fotso |
How to create a user defined attribute |
1 |
5626 |
Wed, 20 June 2012 08:08 By: Cedric Brun |
[Resolved] EMF diagram editor for Juno ? How-to open diagrams created with Indigo, using Juno ... |
1 |
4902 |
Fri, 25 May 2012 20:09 By: Bernard Sarter |
[Texo] Hard-coded date time format ... Any way to change? |
0 |
6353 |
Thu, 17 May 2012 09:21 By: Olaf Burdziakowski |
Association class how can I create a new association class ?? |
0 |
6358 |
Mon, 30 April 2012 21:07 By: Jomaa Narjes |
Limiting access to generated collections |
0 |
6188 |
Thu, 16 February 2012 16:32 By: Hayden Marchant |
Is Ecore tools development dead ? |
3 |
7008 |
Tue, 14 February 2012 14:18 By: Cedric Brun |
[ecoretools] Problem creating opposite ERelation through the graphical editor |
1 |
6558 |
Fri, 10 February 2012 08:29 By: Benoit Cantin |
UI Acceleo Launcher Project fails Acceleo ecore eclipse plugin |
2 |
7087 |
Thu, 02 February 2012 13:21 By: Ribeiro Campelo David |
Extension Point Modeling Framework Using EMF to make extension point development a lot easier? |
0 |
7204 |
Fri, 30 December 2011 01:17 By: Duncan Krebs |
[ECore] How to reference fixed Ecore classes as well as model instances |
3 |
8503 |
Mon, 12 December 2011 09:00 By: Algar fr |
Is it possible to reference eClasses from xmi instances? Referencing ecore eClasses (meta-model level) from instances in xmi (model level) |
1 |
5095 |
Mon, 12 December 2011 08:58 By: Algar fr |
Code gen problem generate a very long do switch statement |
0 |
6322 |
Tue, 22 November 2011 22:33 By: liangzhao.zeng |
Ecore Diagram Manipulation By: Alex on Mon, 21 November 2011 |
0 |
5876 |
Mon, 21 November 2011 22:07 By: Alex |
How to set an class extended attribute |
0 |
6199 |
Mon, 21 November 2011 17:20 By: Patricia Espada |
Proper API documentation in javadoc of generated classes How can I annotate a model with documentation? How can I get rid of "there really should be more of a description here"? |
0 |
7077 |
Thu, 20 October 2011 08:40 By: Martin Domig |
How to set EDateTime in ecore editor? |
0 |
6162 |
Tue, 20 September 2011 19:55 By: Mike Cooper |
[EMF Query]: get the query from the selection |
0 |
6601 |
Sun, 21 August 2011 08:51 By: El Arbi Aboussoror |
removed to correct ng |
0 |
6283 |
Thu, 11 August 2011 14:21 By: js Missing name |
Graphical visualization of Ecore Graphical visualization of Ecore |
0 |
6650 |
Thu, 11 August 2011 14:03 By: djozef87 |
generating model code without reflective api generating model code without reflective api By: thedug on Tue, 09 August 2011 |
0 |
6033 |
Tue, 09 August 2011 02:47 By: thedug |
"Manually" setting xsi-type |
0 |
6665 |
Mon, 08 August 2011 21:10 By: Georg G. |
Modelling exceptions /w emf Howto model exceptions |
0 |
7388 |
Thu, 26 May 2011 17:07 By: Peter Parker |
Ecore models for download By: waqar on Wed, 25 May 2011 |
0 |
6933 |
Wed, 25 May 2011 15:20 By: waqar |
Ecore Diagrams and Loaded resources How to get Ecore Diagrams persisting visual references to elements from other .ecore files? |
0 |
6187 |
Tue, 24 May 2011 15:31 By: Christy Haragan |
[EMF4Net] What ist the status of the project? Anyone still interested? |
0 |
6605 |
Mon, 23 May 2011 22:05 By: Martin Kirst |
Extract all attributes from ecore metamodel By: Carlos on Tue, 03 May 2011 |
0 |
9876 |
Tue, 03 May 2011 13:56 By: Carlos |
Text element of a class By: Ton Tu on Mon, 18 April 2011 |
1 |
4839 |
Tue, 19 April 2011 06:48 By: Ton Tu |
XMI saving is very slow... |
2 |
6275 |
Wed, 13 April 2011 08:06 By: Antoine |
EMF Show model attributes as rows in a table/tree |
0 |
7528 |
Fri, 08 April 2011 06:38 By: Martin Domig |
[EGF] Problems with egfbuild example |
1 |
5462 |
Thu, 07 April 2011 16:33 By: Benoit Langlois |
How to specify database generated ID value in Ecore Editor? |
0 |
6498 |
Wed, 06 April 2011 22:47 By: Mike Cooper |
ecore diagram & ecore tools no ecore diagram is seen under ecore tools |
0 |
6796 |
Thu, 31 March 2011 17:03 By: Cindy Wang |
EMF automatically change "pathmap:/" by "platform:/plugin" |
1 |
5827 |
Thu, 31 March 2011 09:08 By: Marc Mising name |
Setting List<String> Attribute for XML-Element |
0 |
7122 |
Wed, 23 March 2011 10:53 By: Dennis sui |
[Teneo] Teneo 1.0.3 generates foreign key index names too long for Oracle Teneo |
0 |
6816 |
Tue, 22 March 2011 23:57 By: No real name |
create a independent emf project rather eclipse plugins project emf By: liunx on Sat, 22 January 2011 |
0 |
7139 |
Sat, 22 January 2011 05:40 By: liunx |
URI Hierarchy Handler |
0 |
6556 |
Fri, 17 December 2010 17:39 By: Michel Parisien |
Weaving a new model from existing ones By: Steffen on Wed, 08 December 2010 |
0 |
6230 |
Wed, 08 December 2010 12:16 By: Steffen |
accessing ecore model content By: waqar on Mon, 18 October 2010 |
1 |
4915 |
Sat, 27 November 2010 17:13 By: readingflyer |
[EMF/Ecore] Generated editor projects always break after metamodel modifications? |
0 |
6122 |
Thu, 18 November 2010 16:29 By: Glenview Jeff |
Howto make a bidirectional linking between two classes |
1 |
5770 |
Fri, 12 November 2010 15:02 By: waqar |
How to use EType "Sequence" By: hutzu on Wed, 20 October 2010 |
1 |
5405 |
Sat, 06 November 2010 10:24 By: mercedes |
Checking the syntax of EMF query... By: Carlos on Wed, 03 November 2010 |
0 |
5929 |
Wed, 03 November 2010 06:18 By: Carlos |
Ordering Siblings Ordering siblings in the ecore Editor |
0 |
5842 |
Fri, 29 October 2010 13:16 By: Martin Harrigan |
Problem creating a model By: Marina on Sun, 24 October 2010 |
4 |
6500 |
Wed, 27 October 2010 09:37 By: Marina |
How to override the label provider of a referenced model element |
0 |
6521 |
Wed, 20 October 2010 13:30 By: Tom Knipphals |
Top xml element in ecore How to find Top xml element in ecore? |
1 |
4684 |
Wed, 06 October 2010 06:41 By: Volodymyr Gryshko |
How to add child nodes using the reflective API of EMF? How to add child nodes using the reflective API of EMF? |
0 |
6208 |
Mon, 04 October 2010 16:51 By: Adrian Aichner |
ecorediag and ecore mismatch |
0 |
6681 |
Sun, 03 October 2010 16:59 By: Tianfu Ma |
How to deploy a generated editor plug-in |
1 |
4729 |
Fri, 01 October 2010 12:39 By: Kai Maschke |
[Teneo] No primary key in table for multi-valued string attribute By: Lemao on Tue, 21 September 2010 |
2 |
5194 |
Fri, 24 September 2010 13:12 By: Lemao |
Add attribute/reference to diagram which is part of model |
0 |
6679 |
Mon, 20 September 2010 16:22 By: Edaurd Bauer |
Create a snapshot of ResourceSet |
0 |
5723 |
Fri, 10 September 2010 08:25 By: Stephan Au. |
attribute dependencies Attribute Dependency in attributes belonging to different classes |
0 |
5480 |
Thu, 02 September 2010 10:46 By: Santhosh Injineri |
Example of EMF-EclipseLink integration |
0 |
5520 |
Mon, 23 August 2010 08:56 By: Barbara Rosi-Schwartz |
Interdependent attributes By: Amit on Fri, 13 August 2010 |
0 |
4906 |
Fri, 13 August 2010 23:06 By: Amit |
EMF Serialization/Loading question EMF |
0 |
5191 |
Sat, 07 August 2010 05:32 By: Loic JULIEN |
Do bounds (lower and upper) of EReference have any effect? I set EReference lower and upper bounds, but generated Java code lets user to create unappropriate referenced objects count |
0 |
5388 |
Fri, 06 August 2010 15:10 By: Oleg Bolshakov |
attributes in ecore model By: wiwi on Thu, 29 July 2010 |
5 |
6863 |
Fri, 06 August 2010 14:37 By: wiwi |
Displaying blank value in the properties window By: Milind on Thu, 29 July 2010 |
0 |
5478 |
Thu, 29 July 2010 09:47 By: Milind |
How to impl my own quick fix after EMF validation? By: Kevin on Thu, 29 July 2010 |
0 |
4493 |
Thu, 29 July 2010 02:58 By: Kevin |
Integration with EMF Validation |
0 |
5601 |
Sun, 28 March 2010 11:08 By: Juan Cadavid |
